STD Tuning Engine om603.912 hx40
om603.912 hx40
om603.912 hx40
jarow123
07-21-2019, 04:45 PM #1
Hello
Im from Slovakia so i apologise if the spelling or some words might be wrong. I have build a om603.912 superturbo. 8mm dieselmeken pump with outside alda, holset hx40. what is the safe boost a om603NA ? actually i run 1,65 bar without any problems. The engine could handle a pressure of 2 bars ? ?.
Thanks
jarow123
Hello
Thanks
NZScott
HX30W 73/44mm
398
07-22-2019, 04:47 AM #2
I'm sure you'd tell us if it wasn't Smile
With an HX40 your bottom end is probably ok as it won't ever get high boost at low RPM
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
