STD Maintenance General More annoying "What's this?" questions
Gasoline Fumes
Diesel Fumes?
54
05-17-2009, 05:54 AM #1
Can somebody tell me what the following parts do? It's an '85 Federal emissions 300D.
Glow plugs?
[Image: underhoodstuff2.jpg]
What do these parts do? I'd like to make the plate disappear.
[Image: underhoodstuff.jpg]
Driver's side of the firewall:
[Image: insidestuff1.jpg]
Passenger's side:
[Image: insidestuff2.jpg]
Thank you for any info about these parts. Smile
Gasoline Fumes
Glow plugs?
Passenger's side:
05-17-2009, 06:23 AM #2
1: Yes, glowplug relay with a spider egg sack.
2: Melted relay is aftermarket, as is the large box. You'll have to trace them and figure out their function.
A:Cruise control amp
B: ?
C: Wiper relay.
D: ?
E: ?
F & G: Climate control temperature controls.
H: Overvoltage protection relay.
Below H and behind the kick panel door is the EGR computer.
This post was last modified: 05-17-2009, 06:23 AM by ForcedInduction.
B: ?
C: Wiper relay.
D: ?
E: ?
Gasoline Fumes
Diesel Fumes?
54
05-17-2009, 08:39 AM #3
Thanks! Smile
What kind of spider? Tongue
I thought the melted fuse thing might be aftermarket, but the silver relay on that plate looks factory. And I'm pretty sure the black box is factory too, it has a MB part number.
Gasoline Fumes
Thanks! Smile
Kozuka
I'm_Badass
334
05-17-2009, 01:55 PM #4
I would say wolf spider Big Grin
Under my 16V there was blackwidow eggs everywhere and mommy was waiting for me by the fuel pump.
looks like the electric fan relay on my 190.
This post was last modified: 05-17-2009, 01:59 PM by Kozuka.
Kozuka
05-17-2009, 05:56 PM #5
The silver relay is for either the front fan or A/C clutch. Since the black box has an MB part number its probably the alarm system "brain".
Gasoline Fumes
Diesel Fumes?
54
05-17-2009, 11:12 PM #6
Thanks again!
I'll see if I can figure out what the black box is for. And I'll do the same for B, D & E.
Gasoline Fumes
Thanks again!
tantank79
T3-45
109
05-18-2009, 08:58 PM #7
Lol @ the 73-87 Chevy dash
-Brian
1983 300TD
1982 240D
1981 280TE
tantank79
-Brian
1983 300TD
1982 240D
1981 280TE
Gasoline Fumes
Diesel Fumes?
54
05-19-2009, 07:09 AM #8
(05-18-2009, 08:58 PM)tantank79 Lol @ the 73-87 Chevy dash
You should see the truck it goes to! Tongue
The little melted fuse box was spliced into the climate control harness for reasons I'll probably never know. I removed it along with the whole auto HVAC harness.
"A" is the buzzer, I guess the other silver box near it that I didn't see before is the cruise amp.
"B" is the rear defroster relay.
"D" clicks with the ignition switch, but I don't know what it does yet.
The harness from "E" seems to go towards the rear of the car.
Do the locks run off the mechanic vacuum pump, or is there an electric vacuum pump for them?
Here are pics of what's inside the underhood black box:
[Image: IMG_9072.jpg]
[Image: IMG_9073.jpg]
I haven't traced the harness yet. This was on the same bracket as the blue vacuum thing.
This post was last modified: 05-19-2009, 07:27 AM by Gasoline Fumes.
Gasoline Fumes
05-19-2009, 07:55 AM #9
(05-19-2009, 07:09 AM)Gasoline Fumes
Mechanical. There is a reservoir in the trunk.
05-19-2009, 11:30 AM #10
The black box houses the KILMA relay. It is part of the function of the A/C, EGR computer and Tach. That silver relay is the A/C cutout switch relay.
"D" is your power windows relay
"E" I believe is part of the function of turn signals and hazards.
