STD Other FS / WTB / Buying guides Group buy: 8mm MW elements, optional pump rebuild (test elements now being ordered)
  • 1 Vote(s) - 5 Average
Pages (2): Previous 1 2
06-19-2011, 02:54 PM #51
Luck Luck Luck!
Luck Luck Luck!
wlockerb
HX35
27
06-22-2011, 01:23 PM #52
Shut down again guys. minimum order is 50 so not going to happen. I took the advice of an old teacher from my days in the automotive deptarment at ivy tech and call a place called oden machine. He said that they have made custom barrels and plungers before and he would have an answer for me. I called and was amazed at what he told me! He said he knows he could do 10 or 11mm plungers but that he thought a better route to go would be to use an A-pump off of a mercedes combine! He would probably have to regrind the cam for a 5 cylinder but thought the mounting was the same! He wants me to send my pump to him to be sure. I will definitely keep you all posted on this. Oh and by the way, he did say that if I went with the MW pump and 10mm plungers he could do it for around $700-800. Not to bad guys.........
1985 300sd is in the rebuild process now, upgraded pump to 8mm elements(if i can ever get parts), hx35 turbo off of a cummins 5.9
wlockerb
randomdude
06-24-2011, 03:38 PM #53
any new news in the last couple days? i would but at least a couple FOR SURE, if they are found in the under $30 mark.
what kind of power are 8mm's good for with supporting mods? i know there is always a bunch of variables but what kind of range? what size would i need for say, 350wtq?
should my car have a MW pump? it has the square alda on top.
cars? what cars? WHERE???
randomdude
300D50
Graphite Moderator, ala RBMK
07-03-2011, 11:53 PM #54
(06-22-2011, 01:23 PM)wlockerb and by the way, he did say that if I went with the MW pump and 10mm plungers he could do it for around $700-800. Not to bad guys.........
Is that total, with the elements, or total without the elements?
300D50
wlockerb
HX35
27
07-04-2011, 07:37 AM #55
Total with the elements assuming my pump parts are good and nothing needed replaced.
wlockerb
300D50
10-06-2011, 08:10 PM #56
I can get 25 of 1418415043 via paypal for 12.50 each, plus shipping.
They're 10mm Renault.
It's not 8mm, but those seem to be on intergalactic backorder... Sad
Figured I'd throw that out in the open in case anyone was interested...
300D50
10-06-2011, 10:26 PM #57
(10-06-2011, 08:10 PM)300D50 I can get 25 of 1418415043 via paypal for 12.50 each, plus shipping.
Ahh 10mm.... I just can't do it! Too much fuel 4 me!
Let me know if you want me to hook you up with my local shop to install and calibrate the pumps.
This post was last modified: 10-06-2011, 10:27 PM by DeliveryValve.
dalek
10-07-2011, 08:09 AM #58
I'm game for a set of 5 10mm ones.
I am not here to make waves; Sois jeune et tais toi
dalek
mike-81-240d
more like mike-84-300d now
427
10-07-2011, 05:25 PM #59
And they are for the MW pump right? Not the M?
mike-81-240d
300D50
10-10-2011, 10:48 PM #60
MW pump.
My finances are in the red right currently, so I can't order them at the moment...
300D50
MW pump.
02-13-2012, 10:55 AM #61
I'm in for a set of 6 in whatever size we can get our hands on (8mm, 10mm, etc)
Anyone still interested in these? I imagine we could just set the max stop at 1/2 travel for the 10mm plungers...
02-13-2012, 01:39 PM #62
(02-13-2012, 10:55 AM)Simpler=Better I'm in for a set of 6 in whatever size we can get our hands on (8mm, 10mm, etc)
I might be interested if something affordable AND reliable comes along
saquzi
04-08-2014, 12:37 PM #63
Hi!
I was thinking, that is this whole thing in ice? Because i want to know, are there any 8mm or 10mm cheap elements available at this time? Or do someone at the forum have 4 or more elements to sell? :p
saquzi
Hi!
pyrojoe22
02-03-2019, 09:27 PM #64
Updates on this?
pyrojoe22
Updates on this?
