STD Tuning Engine Is it right HX40 on om606?
Savitas
03-17-2011, 06:35 AM #1
Hi guys,
I'm staring my project. I have bought OM606 engine, now looking for om603 pump and bigger turbo. My target is 400-450 hp. Om603 pump will be modyfied with 7.5 elements. Local Holset dealer adviced to use 3591999 or 3593920, this is HX40 turbos. Is he right? He couldn't tell housing size for me. What I'm looking for is HX40 with 14 cm housing. Am I on the right way?
Thanks for your advice
Alius
This post was last modified: 03-17-2011, 06:50 AM by Savitas.
Savitas
Hi guys,
Alius
E300TSC
Turbo-Supercharged
321
03-17-2011, 07:31 PM #2
Hi Alius, the HX 40 will work for your goals but will have some lag unless you fabricate a proper flowing exhaust manifold. I'm using an HX 40 for my project but I'm not sure of the size.
E300TSC
Savitas
03-18-2011, 04:07 AM #3
Who could give me advice about optimum turbine and compressor inducer,exducer size? I still think housing size should be 14 cm^2.
This post was last modified: 03-18-2011, 04:07 AM by Savitas.
Savitas
muuris
OM605
318
03-18-2011, 02:42 PM #4
(03-18-2011, 04:07 AM)Savitas I still think housing size should be 14 cm^2.
Or 16cm^2.
muuris
Or 16cm^2.
jeemu
457
03-18-2011, 02:46 PM #5
(03-18-2011, 02:42 PM)muuris
Or 16cm^2.
I would take that also
jeemu
Or 16cm^2.
E300TSC
Turbo-Supercharged
321
03-18-2011, 09:39 PM #6
The size of the housing is stamped in the divided inlet to the turbine...
E300TSC
Savitas
03-19-2011, 02:28 AM #7
Why are you suggesting 16 cm^2 instead 14 cm^2? Do you thing 14 cm^2 could restrict gas flow out at hight RPM's?
Savitas
03-19-2011, 06:00 AM #8
Not on a 603. A 16cm turbine would be VERY slow to spool up and would make the car bad to drive normally on the street.
jeemu
457
03-19-2011, 06:41 AM #9
Om606, Mynä 7mm, Holset HX40 #17
[Image: full]
jeemu
[Image: full]
George3soccer
03-19-2011, 08:57 AM #10
god those are some nice numbers.
Mb 1984 w201 om603 swap.
Mb 1986 w201 190E 2.3-16v
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
E300TSC
Turbo-Supercharged
321
03-19-2011, 09:44 AM #11
That's pretty much the profile I'm shooting for. Maybe with an earlier rise due to the supercharger... Big Grin
E300TSC
Savitas
03-19-2011, 12:32 PM #12
Jeemu, nice dyno sheet. Could you get us part number of that holset?
Savitas
jeemu
457
03-19-2011, 12:58 PM #13
(03-19-2011, 12:32 PM)Savitas Jeemu, nice dyno sheet. Could you get us part number of that holset?
That is normal Scania Holset. Kompressor 60mm and Turbine 65mm with #17 housing with WG
This post was last modified: 03-19-2011, 12:58 PM by jeemu.
jeemu
03-19-2011, 05:36 PM #14
(03-19-2011, 06:41 AM)jeemu Om606, Mynä 7mm, Holset HX40 #17
Thanks for the example, that fits "slow to spool up and would make the car bad to drive normally on the street" perfectly.
This post was last modified: 03-19-2011, 05:36 PM by ForcedInduction.
muuris
OM605
318
03-20-2011, 02:14 AM #15
(03-19-2011, 05:36 PM)ForcedInduction Thanks for the example, that fits "slow to spool up and would make the car bad to drive normally on the street" perfectly.
If you only had driven one of these, you'd know they are more daily drivable than a normal 300d.
Some people want this. We all get that you don't, that's fine but stop the lingo and be happy with your 617.
muuris
300D50
Graphite Moderator, ala RBMK
03-20-2011, 03:28 AM #16
It's just a turbo swap away, worst case is he'll re-sell and buy one with a smaller housing if the spool time is an issue.
As long as everyone understands the implications of going larger, I'd say we're good.
300D50
George3soccer
03-20-2011, 10:31 AM #17
I have no problem with having a motor run just like that on the street, yet alone be a daily driver. Looks to me its perfect, if it did spool slower then i would like then I would play around with the turbo just like 300D50 said.
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
03-20-2011, 07:00 PM #18
(03-20-2011, 02:14 AM)muuris you'd know they are more daily drivable than a normal 300d.
The T3's turbine is 43mm/62mm and .43ar/6.5cm
The HX40's turbine is 64mm/76mm and 14cm is equivalent to .97ar while 16cm is 1.13ar.
Its physically impossible for an HX40 to perform anything close to like a T3 unless you beat the piss out of the engine to make it spool up. TheT3 will spool up under easy driving around 2000rpm, your dyno sheet shows an HX40 doesn't spool up even under full throttle until 3500rpm.
Quote:if it did spool slower
"slower" isn't an accurate description here, the correct description would be "if it spools without having to flog the engine".
An HX40 isn't very responsive even on the 8.3L Cummins ISC it was designed for. An OM603 at 3500rpm flows the same mass of air as an ISC at its 1300rpm peak torque. There is no way a 603 is going to spool that turbo at any lower rpm with a 14cm housing. A 16cm housing would push that above 4000rpm.
This post was last modified: 03-20-2011, 07:10 PM by ForcedInduction.
yankneck696
395
03-20-2011, 07:35 PM #19
At 2600 RPMs Jeemu is making more power than a stock sized 617 pump can put out (as I remember 145ish hp). Oh, 292.5.... Pound Feet at the same RPM. I would consider that a wonderful daily driver. I wish my F250 had that. I would gladly trade my 302 for his engine.
Ed
yankneck696
Ed
03-20-2011, 07:41 PM #20
(03-20-2011, 07:35 PM)yankneck696 At 2600 RPMs Jeemu is making more power than a stock sized 617 pump can put out (as I remember 145ish hp).
He also has a newer generation engine that naturally flows air far better than a 617, a 605 isn't comparable to a 617. Not to mention that he is injecting far more fuel than any stock MB engine is capable of.
Quote:Oh, 292.5.... Pound Feet at the same RPM. I would consider that a wonderful daily driver.
Yes, if you consider "flooring it everywhere you drive" as "daily driving".
This post was last modified: 03-20-2011, 07:41 PM by ForcedInduction.
MJF
03-21-2011, 08:49 AM #21
You really need to drive one and stop looking only theory.
MJF
George3soccer
03-21-2011, 11:04 AM #22
I dont know what was done to that 606, but there are a few ways to get that boost to spool up faster then what it is doing right at the moment. So you say 3,500rpm is where it starts to act up, you could get that motor to do that same lets say 3,000rpm with a few modifications to the exhust and intake (not sure if there was anything done to it yet) So that makes it 1000rpm away from reacting somewhat a stock t3 would be doing. and on a side note you have allot more hp available at that rpm range then the stock t3. I would take the hx40 over the t3 anyday, even if it takes flogging the motor.
Mb 2004 w203 C230k
George3soccer
Mb 2004 w203 C230k
muuris
OM605
318
03-21-2011, 04:05 PM #23
(03-20-2011, 07:00 PM)ForcedInduction
Did I say HX40 spools up as fast as T3?
I compared these "undriveable" engines to 300d, which is N/A. It doesn't have T3, HX40 or any other. You say it is not a good daily driver?
Drive one and stop moaning. Your theory has been proven wrong by practice and experience. Of course 60x is more modern engine than 617, that doesn't make it less driveable. No one is stupid enough to put a T3 in 60x.
I don't find stock(ish) 617A glamorous even if you wrote ten books about it Wink
I don't find 2500-3000rpm equal to "beat the piss out of the engine".
muuris
300D50
03-21-2011, 08:03 PM #24
Hey, guys, no more personal jabs, or there will be possible points towards vacations..
300D50
03-21-2011, 11:10 PM #25
(03-21-2011, 08:49 AM)MJF You really need to drive one and stop looking only theory.
I have access to a fleet of 15 HX40 equipped vehicles. There is no possible way an HX40 can spool up better on a 3.0L engine than it can on an 8.3L engine. Stop lying.
Quote:So you say 3,500rpm is where it starts to act up, you could get that motor to do that same lets say 3,000rpm with a few modifications to the exhust and intake
The only two ways to make a turbo spool up faster are to increase the exhaust volume or increase the exhaust velocity (VNT).
Quote:Did I say HX40 spools up as fast as T3?
Yes. "more daily drivable than a normal 300d." The only possible way for that to be is to produce the same or better torque at the same rpms. Impossible without at least the same airflow, aka, boost. With the turbo not spooling up until 3500rpm the torque will be little better than that of a non-turbo engine.
Mod_edit: You've used up your freebie, next one won't be a blank.
This post was last modified: 03-22-2011, 12:16 AM by 300D50.
dieselboy
Rotatin 5500 times a minute
680
03-21-2011, 11:35 PM #26
All of those isc 8.3L cummins are pigs and horriably detuned. But he's asking about a hx40 on a om606 not a 603, 617, 605.
There are plenty of videos showing a 606 with a hx40 and they are fine to cruise and then are silly when under boost.
-Jesse
97 f250 psd 4x4, crawler
70 f250 390
83 Volvo 242, lots of mods
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
MJF
03-22-2011, 12:12 AM #27
You can't know how those cars are to drive part throttle by looking dynosheets. When cruising normally, you don't need full spooling with hx40. And boost does not mean same as airflow.
MJF
muuris
OM605
318
03-22-2011, 12:38 AM #28
(03-21-2011, 11:10 PM)ForcedInduction
Please re-read my post and keep in mind 300d is naturally aspirated = does NOT have any turbo.
muuris
dieselboy
680
03-22-2011, 12:42 AM #29
It can't be much worse than a n/a om606 when it's not in boost.
-Jesse
70 f250 390
66 Volvo amazon
dieselboy
-Jesse
70 f250 390
66 Volvo amazon
jeemu
457
03-22-2011, 01:02 AM #30
I put that dyno sheet to show Savitas how HX40 works at 606 on dyno.
But as we all know alla engine are differend so other can make more power than other "same" setup.
It all own choice.
jeemu
It all own choice.
Savitas
03-22-2011, 04:11 AM #31
(03-22-2011, 01:02 AM)jeemu I put that dyno sheet to show Savitas how HX40 works at 606 on dyno.
It all own choice.
Thanks Jeemu for dyno sheet.
I'm not going to use my E36 with Om606 for daily drive, it is for some weekend race. As I see in dyno sheet, it could generate more than 300 Nm at 2000 RPM, it is what I'm looking for.
If you could tell us what other mods were made to this engine it would be great.
Savitas
It all own choice.
jeemu
457
03-22-2011, 06:04 AM #32
(03-22-2011, 04:11 AM)Savitas
It all own choice.
That engine was ever open, so it s fully original.
Just exhaust, Mynä pump and Holset.
If less than 400hp is enough, put HX35 in it.
This post was last modified: 03-22-2011, 06:04 AM by jeemu.
jeemu
It all own choice.
atypicalguy
01-06-2016, 01:28 AM #33
Great thread. Thanks jeemu and muuris. Wonder what fuel level that 7mm pump was set at for the dyno sheet
atypicalguy
atypicalguy
01-10-2016, 01:18 PM #34
Does anyone know anything about how the turbine bypass works on this build, or have any other information beyond this thread?
https://translate.googleusercontent.com/...dqrZ-Bo2cw
atypicalguy
Tito
01-10-2016, 01:32 PM #35
Yeah the manifold feeds the small turbo and a big wastegate can open to breath freely to the big turbo using also exhaust gas from the small turbo. Then the big turbo blows into the small turbo and continues to the engine
Tito
atypicalguy
01-10-2016, 11:41 PM #36
Thanks Tito. I realize it is a typical compound. But does the wastegate open from boost pressure or EMP? If emp, then what pressure, was it difficult to tune, did it have a "valley of death" where boost falls off before the big turbo spools up, and other specifics. Did it work well in ehe end? People always end up selling these compound setups, so they must not work all that well.
atypicalguy
01-11-2016, 11:47 AM #37
(01-10-2016, 11:41 PM)atypicalguy Thanks Tito. I realize it is a typical compound. But does the wastegate open from boost pressure or EMP? If emp, then what pressure, was it difficult to tune, did it have a "valley of death" where boost falls off before the big turbo spools up, and other specifics. Did it work well in ehe end? People always end up selling these compound setups, so they must not work all that well.
atypicalguy, my compound build will use EMP to drive the interstage wastegate. Because the interstate wastegate is there to bypass the small HP turbo when it becomes a restriction (to exhaust gas flow).
I envisage the wastegate spring pressure should be set to similar pressure to the drive pressure requirement of the HP turbo's turbine.
Both the HP and LP turbo internal gates will control compressor output pressure, at least in theory.
That is how my design 'will work' anyway..
atypicalguy
01-11-2016, 05:38 PM #38
(01-11-2016, 11:47 AM)Hario
It all sounds good. But it looks like not too many people have made it work very well. Choosing the correct turbochargers seems difficult.
I think the signal to the small turbo wastegate should be the difference between the intake and exhaust manifold pressures. It should open as the EMP approaches the IMP.
But the large turbo should have a wastegate driven by IMP only.
Maybe the hx30 and hx52 or something. Need to do some math to figure it all out!
Thanks for sharing,
Karl
atypicalguy
Thanks for sharing,
Karl
