STD Tuning Engine anyone running open exhaust?
mr_manny
Diesel Offroad Club
91
11-03-2010, 08:52 PM #1
I'm getting ready to do my exhaust, and am sooooo tempted to dump it out behind the passenger tire Smile
my om617 is not my DD...
thanks
mr_manny
thanks
11-04-2010, 06:17 AM #2
There is no way to get the exhaust over there without causing ground clearance issues.
This post was last modified: 11-04-2010, 06:17 AM by ForcedInduction.
mr_manny
Diesel Offroad Club
91
11-04-2010, 08:36 AM #3
(11-04-2010, 06:17 AM)ForcedInduction There is no way to get the exhaust over there without causing ground clearance issues.
that depends on what vehicle is the beneficiary of the 3.0L turbo :p
Currently I'm in the middle of replacing my Toyota gasser with an om617 - toyota fj40 landcruiser.
I believe some of you may familiar w/Luke's kit (4x4 labs)?
Replacing a motor provides some opportunities, so I'm also going fj60 axles (3" wider) and finally getting power-steering Smile
Going out the back sounds more passenger-friendly then behind the front tire.
I found someone who has a buddy w/a om617 in a jeep w/straight exhaust, going to check it out next friday.
keep you guys posted,
manny
mr_manny
manny
11-04-2010, 06:15 PM #4
Straight pipe it! You wont be dissapointed!
Actros617
What's a spark plug???
49
11-04-2010, 07:40 PM #5
Straight pipe and all you'll hear is droan!!
Actros617
11-04-2010, 08:29 PM #6
Ohhh its worth itCool
11-04-2010, 10:22 PM #7
(11-04-2010, 07:40 PM)Actros617 Straight pipe and all you'll hear is droan!!
I doubt it would matter in a truck like that, probably tons of road noise anywhere but off road! Big Grin
It might be nice to really hear the engine note while he's crawling around though, its not too loud really, in comparison with other motors volume with a straight pipe
This post was last modified: 11-04-2010, 10:23 PM by JB3.
300D50
Graphite Moderator, ala RBMK
11-04-2010, 11:52 PM #8
Heck, go open header and route intake out a snorkle...
This post was last modified: 11-04-2010, 11:52 PM by 300D50.
300D50
11-05-2010, 05:39 AM #9
(11-04-2010, 10:22 PM)dropnosky I doubt it would matter in a truck like that, probably tons of road noise anywhere but off road! Big Grin
Ditto. I believe the tire noise would drown out any drone of the engine.
Interior drone is all about the tip too. Even a simple turndown tip can greatly reduce the noise.
As for that Jeep, I say you should make a stack in front of the right door.
11-05-2010, 09:38 AM #10
Stack and snorkel and take pics!
11-05-2010, 07:17 PM #11
Forced is right about tips...
When I unbolted the exhaust from the down pipe on my 617 turbo the open pipe was facing towards the rear of the car (obviously) and it was crazy annoying. It resonated so bad the exhaust went back on two minutes later.
After that I cut that last section off the downpipe so that the end of the pipe points slightly back right at the ground and I have been driving like that for about three months and love it! I will finish it off coming out the passenger fender someday but for now its great. Sounds super throaty and NEVER resonates one bit.
mr_manny
Diesel Offroad Club
91
11-05-2010, 11:34 PM #12
thought I would share my inspiration Smile
http://www.youtube.com/watch?v=v-rYFWD_yfs
thanks again for the info Smile
mr_manny
nickw
Turbo VO
2
11-09-2010, 12:09 AM #13
My 84 300td is running straight pipe out the right side in front of the rear tire.
The sound is great!!
nickw
George3soccer
11-09-2010, 12:06 PM #14
How low is your 300
George3soccer
How low is your 300
nickw
Turbo VO
2
11-09-2010, 01:21 PM #15
(11-09-2010, 12:06 PM)George3soccer How low is your 300
It's sitting stock, I've had no problems with it dragging I drive off road a lot and it's been ok.
84 300td 4speed manual trans
nickw
George3soccer
11-09-2010, 06:24 PM #16
Well yea stock height is fine. Try putting that in the rear or even try to behind the front right wheel on a very low w201.
George3soccer
11-09-2010, 09:45 PM #17
AH put it out the RH fender like the 300slr
George3soccer
11-09-2010, 11:03 PM #18
I sure wish, ill keep it clean and run it to the rear with a 3" turndown.
George3soccer
Silberpfeil
Slowly Sideways
85
11-10-2010, 02:20 PM #19
(11-05-2010, 07:17 PM)Captain America Forced is right about tips...
I totally agree. When my downpipe rotted and I went to a straight pipe I always thought if it was too loud I could put a supertrapp at the end but found it unnecessary.
Silberpfeil
