STD Maintenance General GD MFing thing won't start.... HELP
MadMaxW126
back from the dead.
39
09-07-2010, 08:56 PM #1
82 300SD.....
Sat for 8 years. Flushed tank and lines. New diesel. New filters. System is bled. New glow plugs. 1000cca battery. I can get it to sort of stumble and smoke after some diesel starting fluid right in the turbo and then it'll rattle a bit but won't stay running. Pulling my hair out for 3 weeks on and off... Also 2 steps from gutting the drive train and fuel system to put up for sale and jam a *gasp* small block chevy in it..... It's blasphemy, I know. So, to avoid this travesty, I need some help. Glow plug relay maybe? Anything?
MadMaxW126
82 300SD.....
George3soccer
09-07-2010, 11:25 PM #2
Does the glow plug light turn on and then shut off. Check the voltage between each glow plug lead should be constant between each and everyone they run in parallel.
George3soccer
SicNick
09-07-2010, 11:47 PM #3
(09-07-2010, 11:25 PM)George3soccer Does the glow plug light turn on and then shut off. Check the voltage between each glow plug lead should be constant between each and everyone they run in parallel.
My advice would be to disconnect the glow plug relay entirely, push the car into direct sunlight(if possible), and while cranking apply starting fluid in small controlled bursts, it should pop off and begin to run on that... Grab a can of Big Blast WD40 and try to keep her running with this. If this works you know you have a fuel issue. Do you have solid fuel leaving your return line circuit?
Also, while you've been cranking and it has failed to start is there visible smoke from the tailpipe? If so, what color?
SicNick
MadMaxW126
back from the dead.
39
09-08-2010, 08:30 AM #4
glow plug light goes on and off. it does it's whole cycle with the buzzing and what not.
fuel isn't the issue. pressure and return lines run nice and solid. no issues with flow. filters are clean. system is always primed before each start just to make sure that it isn't an issue. i'll try the wd40 trick though.
if that doesn't work, then what?
MadMaxW126
09-08-2010, 08:30 AM #5
How are have you verified the fuel system is bled? All new filters? Try swapping the to and fro fuel lines from the tank. You should really put some MMO in the cylinders and let it sit for a few days. Then tow start if you are still having problems.
MadMaxW126
back from the dead.
39
09-08-2010, 09:38 AM #6
all new filters. cracked the lines open and bled them through. since it sat for so long it's had all new filters and fluids along with new brakes, some suspension pieces, tires, etc. this is just the last step is to get it moving under it's own power.
MMO....? excuse the ignorance. it turns over okay, but anything can help.
MadMaxW126
09-08-2010, 01:38 PM #7
Marvel Magic Oil. Helps free stuck rings. I would try a tow start if all else fails. The starter may not be turning over fast enough to build compression with stuck rings.
MadMaxW126
back from the dead.
39
09-08-2010, 02:25 PM #8
marvel snake oil? hell it's worth a try. and tow start... interesting thought. just leave it in first and tow away?
MadMaxW126
09-08-2010, 02:29 PM #9
I forget the specifics but that is the gist of it. 25mph is needed I think.
MadMaxW126
back from the dead.
39
09-08-2010, 02:54 PM #10
i'm gonna try the snake oil. now that i think about it, i'll bet the damned rings are stuck. i think its pressurizing the crank case when its turning over because i'm getting some smoke out of the crank case vent on the valve cover.... interesting. i'll post up results. best access to rings is to take out the injectors, yes?
MadMaxW126
09-10-2010, 10:04 PM #11
Put the small block chevy in....
09-11-2010, 04:15 PM #12
(09-10-2010, 10:04 PM)Captain America Put the big block chevy in....
Fixed. Big Grin
Fixed. Big Grin
MadMaxW126
back from the dead.
39
09-12-2010, 01:22 AM #13
the small block chevy idea is sounding better. 69 orig 350/350 10/20 block i have and especially with the supercharger i have in the garage i want to use for it. it's off of a packard merlin v1650 from a p-51d... 100mm inlet, 10.5" impeller wheel, 25lbs of wartime boost with a shitload of cfm on 1650cid at 20,000 ft Big Grin. that's all for another discussion though.
so. i forgot that i hadn't changed the glow plugs yet... thought i did. realized i didn't when the damned glow plug light didn't come on today. changed 4 out of the 5 (how in the hell do you get that back one out with big mitts?). glow plug light came on. broke a damned return hose thing on injector #1 and cut it down to rig it in, but it needs a new one.... what size/type of hose is that? oh and the magic snake oil did the trick after sitting for a couple of hours (thanks winmutt!!). no more crank case pressure. but now i have fuel, glow plugs, and unstuck rings... and the bastard still won't start. it's cranking kind of slow which could be the battery or the charger. i don't think it's cranking fast enough to catch. i'm gonna try a new battery monday. or if anyone has any other ideas? and another point of annoyance. the asshat before the last owner jammed the damn alternator pivot bolt on so tight that a 4' breaker bar couldn't get it loose. so looks like the alternator with bracket is coming out so i can fix that... how many bolts are on that bracket?
MadMaxW126
09-12-2010, 05:01 AM #14
Big Blocks are slow to rev if not built and would not be very fun in this type of car, if you could get one to fit.... a small block would rap nice and quick and with a turbo 350, 400, 4l60, 4l80, richmond 5, TKO 6. whatever would be so fun and crazy in this car I might have to do one in mine....
Small Block Possy!
Small Block Possy!
MadMaxW126
back from the dead.
39
09-13-2010, 08:37 AM #15
ok. seems my questions were too convoluted in my run-on response. so i'll list em:
1. what is the easiest way to get cyl #5 glow plug out?
2. what size/type of hose is the return hose?
3. engine is cranking slow, besides a new crap battery, what else could be the cause? rings seem to be unstuck, glow plugs are good, has fuel, still no start?
4. how much of a pain in the ass is it to pull the alternator bracket out with the alternator still attached? i can't loosen the damn pivot bolt and would rather not use a torch down there.
thanks boys!
MadMaxW126
thanks boys!
09-13-2010, 12:08 PM #16
1. Ratcheting wrench.
2. 4mm? hose? You can get it pretty cheap at autohausaz.com
3. New starter. Did you change the oil?
4. Try from the bottom?
MadMaxW126
back from the dead.
39
09-13-2010, 01:52 PM #17
1. that's what i thought. i gotta see if i got one that i can use with my big mitts.
2. ok. nothing really weird, just 4-5mm diesel/fuel hose? not vacuum line, right? i snipped off the brittle ends and made it stretch, but i'm sure ill break another one eventually.
3. i'm gonna try a new battery... then a starter. dammit.
4. already tried with a 4' breaker bar after letting pb blaster sit on it for 12 hours. i'm gonna have to take the whole thing out and torch it then i guess. there is not tensioner bolt. some gorilla pinned the bastard in place and tightened the hell out of the bolts to keep it in place. god only knows how long it's been like that. i took the belts off by taking off the water pump pulley but couldn't get em back on that way.
thanks again winmutt!
MadMaxW126
09-13-2010, 02:01 PM #18
If you need a quick cheap fix on the return lines you can use weed eater fuel hose but it will not stand up to the heat.
Use a bigger bar (or your doing it wrong).
This post was last modified: 09-13-2010, 02:01 PM by winmutt.
MadMaxW126
back from the dead.
39
09-13-2010, 02:19 PM #19
ahh. okee.
4' brake going counter clock wise. i couldn't get a good look at it at 1am, but it wouldn't surprise me if it was tack-welded in place. the slide bolt was. that's why i'm gonna have to pull it.
MadMaxW126
ahh. okee.
Silberpfeil
Slowly Sideways
85
09-13-2010, 02:20 PM #20
[quote='MadMaxW126' pid='17513' dateline='1284272528']
Where did you manage to scrape one of those things up?? You've got to let us know what you end up doing with it.
Silberpfeil
MadMaxW126
back from the dead.
39
09-13-2010, 02:55 PM #21
ebay. i almost ended up with 2. i got the nicer of the 2 though. i'll post up pics of it later. it's going on that engine. i'm working on designing the fueling system for it right now. it's looking like i'm going to have to build my own propane mixer as the commercially available ones may get destroyed by this thing either via vacuum or boost levels.
MadMaxW126
09-13-2010, 02:58 PM #22
Relic!
Relic!
MadMaxW126
back from the dead.
39
09-13-2010, 03:05 PM #23
ya. it's sort of the crowning jewel of my garage. i'm trying to find an old radial engine or 2 to play with and stuff in something for the right price. i can find plenty of turbo jets and such and hardly ever a radial for the right price.
MadMaxW126
Silberpfeil
Slowly Sideways
85
09-13-2010, 03:20 PM #24
(09-13-2010, 02:55 PM)MadMaxW126 ebay. i almost ended up with 2. i got the nicer of the 2 though. i'll post up pics of it later. it's going on that engine. i'm working on designing the fueling system for it right now. it's looking like i'm going to have to build my own propane mixer as the commercially available ones may get destroyed by this thing either via vacuum or boost levels.
I gotta ask how much you paid.
Silberpfeil
MadMaxW126
back from the dead.
39
09-13-2010, 03:27 PM #25
$318 shipped. a couple of air museums have offered me between $4500-6500 for it because it's a restoration grade piece. still won't sell though. it's just too damned neat.
i forgot i had a pic on the computer here at work. it's on a standard 12" stool. pic is taken kind of at an angle, but you get the gist.
This post was last modified: 09-13-2010, 03:32 PM by MadMaxW126.
MadMaxW126
09-13-2010, 04:20 PM #26
your gonna try and use that on a SBC!?!
MadMaxW126
back from the dead.
39
09-13-2010, 04:50 PM #27
sold my dodge v10, bb ford and bb caddy stuff, so ya. block is ribbed, studded and all that non-sense. working with a couple manufacturers for my options on a crank and rods. pistons are picked out. heads are gonna be iron, big ass cfm 2.08/1.60's from afr which will be o-ringed. i'm gonna adapt everything to a single plane open intake manifold. anything that needs to be milled/made/modified can be done at my bro-in laws machine shop for a couple bottles of crown and the cost of materials. all dry sump. i may send all my stuff out to decatur to be cryo'ed as well. waiting on a quote for it. shooting between 1000-1200hp at the crank as all the flow numbers are theoretical on the supercharger as they didn't map things out like they do now. transmission depends on what it gets stuffed into. still looking for a sub 3500lb carcass with a 34 cd or lower for a close to free as they come. whatever it is, it's getting cut up for a frame and to mount this silly thing. we're building it for a texas standing mile run. all in all, it's a long term project unless i come across someone to sponsor something this ridiculous.
oh, and i know it's somewhat on the wtf are you thinking side. so i am taking bets on how long it'll live since it's sole purpose is building lots of speed very quickly going (hopefully) straight in one direction and then (hopefully) stopping.
This post was last modified: 09-13-2010, 04:52 PM by MadMaxW126.
MadMaxW126
09-13-2010, 05:31 PM #28
that reminded me of the train supercharger!!! http://www.youtube.com/watch?v=v0qeYd5gcnQ
This post was last modified: 09-13-2010, 05:36 PM by willbhere4u.
09-13-2010, 06:09 PM #29
Hahahahahah. that sounds perfect to me. Do I think your crazy, no. Do people think people like us are crazy, yes. Sounds awesome. I need to see more on this project.
Rudolf_Diesel
Ask me if I care...
09-13-2010, 06:29 PM #30
That train S/C is quite a feat of engineering and I give him some credit....but it is kinda like these, sure they are big, but dayam, a little too big!
Rudolf_Diesel
09-13-2010, 11:08 PM #31
It takes a classy kinda lady to get basketballs as implants!
This post was last modified: 09-14-2010, 09:29 AM by willbhere4u.
MadMaxW126
back from the dead.
39
09-14-2010, 08:28 AM #32
hey look! flotation devices!
anywho
1. threw a new, fully charged battery in it and it still cranks slower than shit. looks like it's getting a starter.
2. we got the damn alternator to move! apparently soaking the entire mess with pb blaster for a couple of days and getting pissed and hitting it a big ass wrench was enough of a motivator. still can't get the damned bolt out, but the alternator moved.... so i'm not as worried about it right now.
so all in all.... progress!
MadMaxW126
anywho
MadMaxW126
back from the dead.
39
09-20-2010, 08:08 AM #33
UPDATE:
I didn't get a chance to throw the starter in this weekend (looks like it is going to suck donkey taint). But for fun, I charged the piss out of the battery and had it hooked to a rigged up 1500cca jump box... It turned over fine!... but still won't catch. I used a combo of vaporized wd40 and diesel starting fluid and could get it to stumble... still wouldn't light off entirely. I'm gonna swap in new filters tonight and see what happens. It now seems to be a fueling issue. There's fresh diesel and diesel clean in it. Any other ideas?
MadMaxW126
UPDATE:
09-20-2010, 12:40 PM #34
Good luck hope it's not an injection pump issue! But that wouldn't be the end of the world either they are readily available and cheap through the right sources!
MadMaxW126
back from the dead.
39
09-20-2010, 01:43 PM #35
see. that's the thing. besides this one, i have only seen maybe 15 of these with a diesel in the wild, EVER with in a 100 mile radius from work/home. there are none in the junkyards. none on lkq. they don't die and/or people don't get rid of them around here. so i hope changing the filters and what not works.
MadMaxW126
