648 oil pan on 606 questions
Hey everyone,
I've got the rear-sump oil pan from the 648 on my 606, and have two questions.
1. The dipstick tube from the 648 has been installed (near the back of the block, intake side) and I'm wondering if I can leave a dipstick in there while the engine is running, or if I must remove the dipstick when the engine is running? I have a generic dipstick that fits well enough.
2. There is a large opening in the pan at the rear, where the flywheel is visible.
I circled it in red in this image: http://imgur.com/qOtnL75
Is there a cover or rubber plug for that? I really don't want to pickup mud/stones in there.
Thanks,
-Dan
Curious about that also. Is it a web site like W124-zone.com? Grecy, did you use the oil pump,pickup tube and special main bearing bolts to secure the pickup tube?
Curious about that also. Is it a web site like W124-zone.com? Grecy, did you use the 648 oil pump,pickup tube and special main bearing bolts to secure the 648 pickup tube? Know any good sources?
(12-08-2015, 02:42 PM)hooblah Anyone know the torque specs for main bearing bolts?
think there 60nm and 90 degs
