STD Tuning Engine om606.962 idling issue
50harleyrider
GTA2359VK
397
11-23-2022, 10:11 AM #1
I'm having a problem in my DSL1 controlled engine with idling at warmup temperature. My truck performs flawlessly for 10-15 minutes running time until suddenly won't idle right and tries to stall. it doesn't respond to pedal when this occurs and will hardly start. The fuel filter is fresh. it does appear to be a fueling issue but I need to know if it's a rack issue in the pump and what I can monitor to pinpoint the problem. The pressure to the pump is set at the minimum as I have a constant running lift pump and installed a bypass regulator per my previous thread. It had been running fine for several months before this problem occurred. I hope the IP isn't dying.
This post was last modified: 11-23-2022, 10:13 AM by 50harleyrider.
50harleyrider
baldur
Fast
506
11-23-2022, 07:36 PM #2
Do you have a data log of this?
Baldur Gislason
baldur
Baldur Gislason
50harleyrider
GTA2359VK
397
11-24-2022, 10:54 AM #3
baldur Do you have a data log of this?
I will get a log today and send it to you. thanks
50harleyrider
