STD Tuning Engine om603 6mm elements
om603 6mm elements
om603 6mm elements
PedroFerreira
12-16-2014, 06:29 PM #1
how much hp can 6mm elements do in om603?
PedroFerreira
baldur
Fast
511
12-16-2014, 06:39 PM #2
'bout 300.
Baldur Gislason
baldur
'bout 300.
Baldur Gislason
PedroFerreira
12-16-2014, 06:42 PM #3
can do more that in om605?
PedroFerreira
baldur
Fast
511
12-16-2014, 07:33 PM #4
No it'd do less, since the 605 only has 5 cylinders while the 603 has 6 of them.
Baldur Gislason
baldur
Baldur Gislason
PedroFerreira
12-16-2014, 07:40 PM #5
the om605 whith 6mm (stock) can do 260hp.om603 whith 6mm ip can produce 240?or less?
PedroFerreira
baldur
Fast
511
12-16-2014, 07:41 PM #6
Given that OM603 has 6 cylinders and thus one extra pump element, it'll be able to produce about 300 horsepower.
Baldur Gislason
baldur
Baldur Gislason
PedroFerreira
12-16-2014, 08:28 PM #7
but the om605 had 20v and om603 only 12...
PedroFerreira
rafael cotrim
Holset hx55 eaton90
22
12-17-2014, 01:58 PM #8
Pedro , Is what i already have told you, I guess....
This post was last modified: 12-17-2014, 01:59 PM by rafael cotrim.
If it don`t blow smoke , it must be broke ! W201-Angel
rafael cotrim
MrHope
12-26-2014, 10:47 AM #9
Om605 with 6mm on dyno 274hp on crank.
http://www.maxxtuning.se/kundbilar/effek...w123--jim/
W124 300D 1985 (daily driver)
MrHope
bruno_pinho
12-26-2014, 03:31 PM #10
(12-26-2014, 10:47 AM)MrHope Om605 with 6mm on dyno 274hp on crank.
I do not believe in 174 to 1.5bar...
bruno_pinho
Petar
7.5mm M pump
459
12-26-2014, 04:35 PM #11
(12-26-2014, 03:31 PM)bruno_pinho
What don't you believe ? That engine is only making 380 NM's of torque but with the torque curve shifted up in the rpm range to make more power.
Petar
starynovy
12-26-2014, 04:43 PM #12
Very nice, is that yours?
starynovy
bruno_pinho
12-26-2014, 04:49 PM #13
(12-26-2014, 04:35 PM)Petar
Sorry but I do not believe these numbers to 1.5bar ...
bruno_pinho
F.R.A.S
12-26-2014, 05:08 PM #14
That's not 6mm elements in that video and the owner Jim is a friend of mine.
6mm can't ever do 300hp forget about that.
F.R.A.S
bruno_pinho
12-26-2014, 05:22 PM #15
(12-26-2014, 05:08 PM)F.R.A.S That's not 6mm elements in that video and the owner Jim is a friend of mine.
I did 260cv and 417nm with 6mm and electric pump with 1.8,1.9bar..
This post was last modified: 12-27-2014, 07:37 AM by bruno_pinho.
bruno_pinho
