Audi 5cyl rotary pump
(07-01-2009, 09:28 PM)winmutt I want to find the Audi 5cyl rotary pump. Plenty of upgrades for that line. and from what I have seen it has the same driveinterface.Is the Audi pump for a diesel or do the bosch mechanical F/I pumps work the same way as diesel I/P's do, who has the best pumps so far?
(07-04-2009, 11:09 AM)Motorhead It looks like it is cog belt driven, it would not be a bad install.
All you have to do is put the spline snout on the shaft and bolt it up. I dislike rotary pumps though, I wouldn't do it.
(07-04-2009, 03:09 PM)ForcedInduction I dislike rotary pumps though, I wouldn't do it.
Personal preference. I've always seen inline pumps as the better pumps.
This a gut feeling, or do you think mechanically that the rotary is a lesser unit? ie: longevity, adjustment, failure issues, etc.
I am just curious about these pumps, and if it would be an option that would allow easier tunability, plus the fact that there is an aftermarket parts availability for them.
(07-05-2009, 12:51 AM)Telecommbrkr This a gut feeling, or do you think mechanically that the rotary is a lesser unit? ie: longevity, adjustment, failure issues, etc.
(07-05-2009, 08:14 AM)dalek ForcedInduction said he would not do it.
I am just here to lurk and maybe ask a few questions. The last thing I want to do here is to prove anyone wrong. I just thought someone would want to see the Audi pump; if that was seen as stepping on people's heads, I do apologize.
(07-05-2009, 08:49 AM)dalek I just thought someone would want to see the Audi pump; if that was seen as stepping on people's heads...
PartsPlace Inc seems to have a lot of VW/ Audi diesel stuff for sale. Their sales dept. phone number is (248) 373 2300. From their website:
http://www.partsplaceinc.com/
The drive is a tapered 17mm OD shaft and a respective woodruff key with the drive pulley held in place with a nut. The flange is a similar 3 bolt style to the inline pump. A machine shop might be able to help spline the driveshaft provided there is material that could be removed.
Alternately, a Gilmer belt sprocket could be salvaged as a bushing with splines machined into it, so the 617 sprocket would fit. I am not sure of the ID of the 617 sprocket, however.
The audi based pump can be fitted with a 12mm diameter plunger/head from stock bosch parts, and there are custom 14mm diameter plungers available as well. With a suitable cam plate, the pump will yield about 75% more fuel compared to the stock plunger ( I last recall it is 10mm in diameter ) and well over 100%
with the 12mm and 14mm plungers respectively.
Many cam plates are available too, and the stock cam plate is very benign. A higher lift cam plate gives more fuel as well, so a combination of a larger diameter plunger and the cam plate is what you would want.
The 617's timing advance would need to be disabled, or retain it, and keep the inline pump's sprocket timing advance fixed. I would consider trying the latter, which allows you to tune the timing via the VE pump.
Stronger plunger springs can be fitted to keep cam plate float in check for over 6K rpm operation easily. Indeed, no oil feed is needed for the VE type pumps.
(07-06-2009, 05:53 PM)Motorhead So there is a timing advance in the 617 pumps, how much and at what rpm?
Great info 606Power
What year(s)/model(s) of audi did these pumps come in?
Is the pump Volvo uses for it's 5cyl diesels a rotary as well?
(07-06-2009, 11:17 PM)Telecommbrkr Great info 606Power
I'm pretty sure all the Volvo diesel's used VE rotory pumps, for automotive applications anyway. I know the 6cyl diesel was made by VW, not sure about the 5. I still do not see why one would want to swap over to a VE, but who knows, it'd be interesting to see it happen.
I believe some Duetz 5cyl used a variation of the VE too.
On ebay, there were some new 5cyl Bosch VE pumps from some weird generator application (maybe Duetz, didn't say) The place also had a 4cyl Onan VE pump which I installed in my Samurai, turned out to be a Cummins 4BT 12MM pump brand new for 140 bucks! It had many differences from the automotive version, but I got it sorted out and it's working well on the Samurai - had to turn it way down though - it would smoke truck pull style when I first installed it!
Sure, anytime.
I do not recall the years exactly, but perhaps 83-84. An NA pump would be fine as well, since you can get the turbo/aneroid/LDA top cover, and fit it onto the NA pump.
If you cannot get the aneroid top cover, the pump can still be tuned similarly for power, but will have less off boost smoke control. The aneroid is limited anyway when it comes to increasing the plunger diameter.
VW did use the VE mechanical pumps in their euro 2.5L engines as well, which could be another source for parts/pumps.
Volvo 240s did use the same NA 5 cyl engine as was used in the Audi 5000, but in Europe as far as I know, and was designated the D20.
