STD Maintenance General W123 tachometer
W123 tachometer
W123 tachometer
RonB
02-22-2012, 06:06 AM #1
Hi, down here in OZ ,none of our diesels came with a tacho , how do they pick up a signal from the engine? is it a hall effect pickup? Could one from a gas powered car be made to work using the diesel wiring? .
HuhHuh
RonB
HuhHuh
02-22-2012, 09:27 AM #2
There is a hall effect sensor at the crank by the harmonic dampener. It goes to an amplifier, and then the gauge cluster in the car.
02-22-2012, 10:47 AM #3
You could probably fab up a pick up sensor and make a converter box to run the gas tach
RonB
02-23-2012, 06:18 AM #4
Does anyone have a part number for the amplifier and cable?
RonB
02-24-2012, 02:53 AM #5
This might help.
Adding a Tach
This might help.
Adding a Tach
RonB
02-24-2012, 04:24 AM #6
(02-24-2012, 02:53 AM)Captain America This might help.
Adding a Tach
Hey thanks!! i did a search of the site and never found that thread.
It's a pity the W126 tacho will not fit in a W123 cluster because i have a pile of them. I now know how to work a W wire into a alternator and the 6 pulse rule . Even at my age i can learn stuff everyday ..ha ha ha
Anyhow, using a W wire i do not need to worry about a tach amplifier ,but i also learned how they are just the diagnostic plug with the amp plugged into it so i'll go the simpler route.
RonB
Adding a Tach
