STD Tuning Engine 603 n/a fi element update
inkblotz
Thundering Turtle
47
04-06-2011, 05:37 PM #1
I have a none turbo 603 motor which is rather slow. I have read some posts where people have replaced the elements to the larger 6-7mm size to increase flow. Is this procedure primarily beneficial for turbo motors or will I achieve additional power for my non turbo motor?
My goal. I really want the best long term durable diesel (like a 617A) not necessarily a tire burner. I will be doing all the work.
Additionally what are your thoughts on a 606n/a transplant instead. With its mechanical fi pump it seems to be fairly plug and play other than reconfiguring the exhaust?
Thanks
Mark
1990 300GD SWB 463 Diesel W/ OM603A Turbo Diesel transplant
inkblotz
Thanks
Mark
babymog
04-06-2011, 05:41 PM #2
On this board it'll be go turbo or go home. Otherwise, my answers are the same as on the other board.
'87 300TDT "Pandora"
Garrett T-30 .55 @ 18.5psi, .970 IP @ 13.5ATDC turned up, #22 head with oblique injection, 4-puck brakes, 215 Michelins on 16x8" Bellos, updates etc.
http://www.youtube.com/watch?v=RZCI0BTWKx8
babymog
inkblotz
Thundering Turtle
47
04-06-2011, 05:44 PM #3
Understood and well said.
Thanks
Mark
inkblotz
Thanks
Mark
04-06-2011, 05:53 PM #4
You need a turbo to do anything... be it a slap on turbo or an entire turbo engine.
erling66
SuperDieselVan
294
04-06-2011, 06:23 PM #5
I had a W124 603 n/a and I put a 606n/a in it. It is a fairly easy swap. But you have to rev up the 606n/a to get some power from it. Not the best solution in a G wagon. And I have heard that the large intake will hit your power brake. Why not put an Eaton M90 supercharger on it since you mainly need low end torque?
HuhCoolTongue
erling66
HuhCoolTongue
babymog
04-06-2011, 08:13 PM #6
He's running out of power on the freeway, probably has plenty down low with low range and all.
babymog
pp d
04-07-2011, 12:12 AM #7
Bigger elements gives more power to n/a engine too.
Not as much as turbo, of course.
pp d
inkblotz
Thundering Turtle
47
04-07-2011, 08:36 AM #8
I am looking at all my options right now. I am not sure about attaching a turbo to my existing engine. Yes it would be straightforward to do but will the N/A designed engine be able to handle the added pressure. Of course if i did this I would need to increase the elements anyway or attach a fi pump from a turbo motor to get the ALDA unit. This would definitely shorten the life of the engine.
erling66
Some of the later G wagens came with the 606A motor. no issue with the power brake.
I have attached a photo.
I also attached a photo of a 606 in a G that went swimming.
On the G350 motor to keep the air filter on the right hand side MB ran a pipe over the valve cover from the air filter to the turbo and then from the turbo back to the air intake. (a lot of plumbing).
pp d
If I were to go to the 6-7mm elements would this give me a little extra overall power especially on the highway? I intend on doing some cross country (coast to coast) trecks and would like a dependable long distance driver.
Mark
This post was last modified: 04-07-2011, 08:56 AM by inkblotz.
inkblotz
erling66
pp d
Mark
pp d
04-08-2011, 12:18 AM #9
(04-07-2011, 08:36 AM)inkblotz pp d
Mark
I installed the Floyd 7,5 elements to E 220 D 604 engine, non turbo.
The different is like night and day. I have not tested in long run yet but so far I`m satisfied.
pp d
Mark
inkblotz
Thundering Turtle
47
04-09-2011, 02:12 PM #10
OK a little update after speaking with Gus Pfister at Pacific Fuel Injection in California it was determined that why the performance of my diesel is so lackluster is that it is not getting enough fuel. As i mentioned the PO had the pump rebuilt but upon install I don't think it was set up properly. The full load adjustment screw (behind the plate at the the back of the injection pump) needs to be backed out to increase the fuel flow.
With the car in neutral if I punch I don't get much smoke at all.
Any input as to the easiest way to get to it short of pulling the pump would be appreciated.
Mark
inkblotz
Mark
tomnik
04-09-2011, 03:02 PM #11
don't know the engine bay in a G but it should be enough to remove the intake manifold to access the back of the IP.
You can run the engine (not driving) with open back plate and removed intake for some seconds just to get an idea of engine response and smoke.
But you will reach the limit (smoke, high egt) before you are happy with performance.
Tom
tomnik
Tom
inkblotz
Thundering Turtle
47
04-09-2011, 03:49 PM #12
Great thanks The oil filter appears to be the biggest obstacle to getting that back plate off but worth a try.
I will post what I find.
Thanks
Mark
inkblotz
Thanks
Mark
kotka
04-10-2011, 11:03 AM #13
i have the same issue - G463 300D'91 with a/tranny
really slow on-roads and not too much efficient off-road.
i target to:
1) switch engine to 606a
2) put larger plungers
3) thinking of vnt/vgt with mechanic vacuum management
first two are not that difficult but the last one is a challenge
so finally i will have fully mechanic g-wagon with automatic transmission - nice mixture of offroader and day-to-day car Smile
kotka
i target to:
inkblotz
Thundering Turtle
47
04-12-2011, 06:17 PM #14
(04-09-2011, 03:02 PM)tomnik don't know the engine bay in a G but it should be enough to remove the intake manifold to access the back of the IP.
Tom
Tom You are right I looked at it today and I will have ample room to make the adjustment. For some reason I had the 617A on the mind when I was thinking about the restricted access because of the oil filter. Not so with the 603.
I am nursing a fully torn achilles so i am crutching it for now. Maybe this weekend.
Mark
inkblotz
Tom
Mark
inkblotz
Thundering Turtle
47
04-16-2011, 10:15 PM #15
Well I addressed the entire fuel system today.
1. Changed out the filters.
2. Blew at 10psi compressed air back through the fuel inline to clear the screen. This is a temporary fix to see is the screen had some algae growing that is hindering flow.
3. Replaced the return lines, as they were old and weeping.
4. I took the end plate off the FI pump and adjusted the lower left fuel enrichment screw. You unlock the 10mm nut then back out the screw. Run the engine with the plate off. (yes there will be some engine oil that will come out) and keep adjusting till you start to get the over-rich black exhaust. Then back in the screw a bit till there is minimal smoke. Then lock down the securing nut, put the plate back on and off you go. I have attached a photo that I borrowed from poster WINMUTT.
5. Additionally I took out my fuel sender and went fishing in the tank for possible algae blooms. None were to be found.
I took it for a test drive and definitely noticed an increase in power.
One more added bonus to the FI pump adjustment: the engine has, since I bought it idled at 500 rpm. Now it idles at what the factory calls for 750 rpm.
Thanks all for the assistance/input.
Mark
This post was last modified: 04-18-2011, 03:21 PM by inkblotz.
inkblotz
Mark
04-18-2011, 12:53 PM #16
Stealin my pics! Big Grin
Is that Georgia US or Georgia the country?
inkblotz
Thundering Turtle
47
04-18-2011, 03:23 PM #17
I now have revised the post to give you full credit. Where in Atlanta are you? I am in Norcross.
Mark
inkblotz
Mark
04-19-2011, 09:07 AM #18
Just yanking your chain. I live in west buckhead work off delk. We should have a beer sometime.
inkblotz
Thundering Turtle
47
04-19-2011, 07:04 PM #19
Sounds good.
M
inkblotz
Sounds good.
M
