STD Tuning Drivetrain Ebay.de goodies
Ebay.de goodies
Ebay.de goodies
03-24-2011, 08:59 PM #1
So winmutt's manifold score inspired me to poke around on ebay.de. The result was this:
A "5 gang kardanwelle". No it's not supposed to poke out the box like that. Still pretty sweet though.
300D50
Graphite Moderator, ala RBMK
03-24-2011, 09:13 PM #2
Ohhh, that will be FUN!
300D50
03-24-2011, 11:10 PM #3
a what?
a what?
03-25-2011, 04:21 AM #4
5 speed driveshaft.
Pic:
Hmm, uses the small flanges. I was hoping for the larger style flexdisc. Each half is around 32" long.
This post was last modified: 03-25-2011, 01:48 PM by aaa.
5 speed driveshaft.
Pic:
03-25-2011, 08:55 PM #5
Um, you do know that the center support is in the wrong location..... Thats a 280E driveshaft.
This post was last modified: 03-25-2011, 08:55 PM by ForcedInduction.
03-25-2011, 08:57 PM #6
That would suck. Gonna bust out the measuring tape at some point.
03-26-2011, 11:16 AM #7
In the picture attached, you can see the difference in support positions from the 300D and 280E. (280E 5-speed top, 300D 4-speed bottom.)
03-26-2011, 07:42 PM #8
Seemed to line up when I held it up underneath the car. Center support in the right place and everything. The splines are bigger than the 190 shaft as well, maybe the same as the 300d splines, at least that's what I'm banking on.
Now if only I can figure out these flanges... Turns out it's not the same as the 190 flange, it's ever so slightly bigger. So apparently there's at least three different types of these output flanges/flex disc sizes floating around. On the plus side it seems to match a 617 flex disc. So I think I'll grab the output flange off of the toasted 617 4-speed I have since the 190 output flange doesn't look like it'll go with this.
03-27-2011, 07:45 AM #9
So apparently the 201 2.2L disk has an 80mm diameter bolt circle, while the driveshaft is 90mm, matching what the 123's use. I'm guessing what 87's have to begin with is 100mm, or maybe 110mm (for some reason couldn't find a flexdisk lying around, thought I had one). (Edit: they're 110mm)
Here's some link I found with all the sizes and part numbers:
And here's a link to the big 110mm version of the googley-eyed flex discs the 85+ manual trans cars used.
http://www.autohausaz.com/search/product...%2006%2015
This post was last modified: 03-27-2011, 07:59 AM by aaa.
03-28-2011, 02:39 AM #10
Perhaps you should fill out a profile and signature so we know what vehicles we're talking about.
This post was last modified: 03-28-2011, 03:27 AM by ForcedInduction.
03-28-2011, 03:24 AM #11
Or maybe I should have said which I was talking about to begin with, since I have both. This is an 87 w124.
