FAQ EDC Pumps / W202/W210 W463 ECU’s
If your using your own ecu your immo stays the same, but in order for me to supply a spare ecu i need to deimmo to test and confirm it works in any car.
Other solution is send me your ecu and i can duplicate the immobilser and you get a spare socketted and remapped ecu and leave stock one alone.
Either solution needs no changes to any modules on the car, These ecus work with the stock tcu for 722.6 yes and also without.
The plugs are the same on both ecus, i have also swapped om606/om605 maps between ecus and they work fine..
Sean
