STD Other Trucks, semis, vans, transporters and mogs. '92 Dodge Dakota : OM617 Conversion
74Dusted
07-22-2015, 09:58 PM #11
Been a long while since I posted any updates.
Engine/Transmission are in the truck. I ended up keeping the Merc Auto trans behind the 617 for now, until I can get around to gathering up everything for a 5-Speed Manual Swap.
Out with the beat 5.2L Magnum V8 (gave it to my dad to use for parts for his 5.2L powered Ram 1500). My poor 5.2L had 4 dead cylinders and the other 4 ranged between 50psi and 70psi compression... She still ran and drove, matter a fact, I drove it for a couple months like that, before finally parking it.  She sat for over a year after that. I climbed in, cranked the engine over and she sputtered to life one last time...for her trip into the garage for the engine to be removed.
[Image: image_zps288e6b13.jpg]
[Image: image_zpsb7062f3d.jpg]
[Image: image_zpse49327b2.jpg]
[Image: image_zps17563bf0.jpg]
In with the 617. Ended up bolting the transmission to her on the floor, and with a not so helpful helper, some swearing (okay, lots of swearing...mostly because the helper was supposed to be "spotting" clearances...clearances that put a dent in my core support because he wasn't watching) and some crafty chain placement, I was able to wrestle the Engine/Transmission into the truck in one assembled combination.
[Image: image_zpsc974bac5.jpg]
[Image: image_zps0b24c83c.jpg]
[Image: image_zpsf0b499d9.jpg]
[Image: image_zps01731233.jpg]
[Image: image_zpssklvotij.jpg]
[Image: image_zps7rlnng8p.jpg]
Figure this one out... The OM617 weighs more than the 5.2L, yet the front of my truck sits 3" Higher than it did with the V8.
[Image: image_zpsdw6b2il2.jpg]
Salvaging parts from a Dodge D50 Instrument Cluster, to install in the factory Dakota Instrument Cluster... Yes, that's a Gasoline D50 Cluster, with factory Diesel Indicator Lights in it.  A 2nd Gen D50 Cluster at that, the Turbo Diesel was only a 1st Gen D50 Option (that cluster is 3 years newer and completely different from the 1st Gen Diesel Cluster).  I'm not complaining, it gave me parts to make my Dakota look more "factory"
[Image: image_zps06bc5odd.jpg]
[Image: image_zpseg5jqt1u.jpg]
Necessary extra gauges
[Image: image_zpswhbpiswv.jpg]
[Image: image_zpsshkahb3x.jpg]
[Image: image_zpstgqicw6x.jpg]
'92 Dakota 4x4 : OM617/Auto/205
'84 D50 4x4 : 273/727/100/203 (former turbo diesel truck)
'73 Duster : Roots 6-71 Blown 340/833
74Dusted
Messages In This Thread
'92 Dodge Dakota : OM617 Conversion - by 74Dusted - 10-31-2014, 08:25 AM
RE: '92 Dodge Dakota : OM617 Conversion - by Simpler=Better - 10-31-2014, 09:37 AM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 10-31-2014, 01:15 PM
RE: '92 Dodge Dakota : OM617 Conversion - by Simpler=Better - 10-31-2014, 01:26 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 11-03-2014, 08:24 AM
RE: '92 Dodge Dakota : OM617 Conversion - by SurfRodder - 03-01-2016, 10:50 PM
RE: '92 Dodge Dakota : OM617 Conversion - by Petar - 11-03-2014, 05:14 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 11-03-2014, 06:20 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 11-05-2014, 10:05 AM
RE: '92 Dodge Dakota : OM617 Conversion - by MFSuper90 - 11-05-2014, 01:51 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 11-05-2014, 02:43 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 07-22-2015, 09:58 PM
RE: '92 Dodge Dakota : OM617 Conversion - by Simpler=Better - 07-23-2015, 01:01 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 07-23-2015, 09:24 PM
RE: '92 Dodge Dakota : OM617 Conversion - by Simpler=Better - 07-24-2015, 12:31 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 07-24-2015, 10:45 PM
RE: '92 Dodge Dakota : OM617 Conversion - by MFSuper90 - 07-27-2015, 09:35 PM
RE: '92 Dodge Dakota : OM617 Conversion - by MFSuper90 - 01-21-2016, 06:50 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 02-26-2016, 03:12 AM
RE: '92 Dodge Dakota : OM617 Conversion - by MFSuper90 - 02-28-2016, 10:58 AM
 7 Guest(s)
 7 Guest(s)
