STD Other Trucks, semis, vans, transporters and mogs. '92 Dodge Dakota : OM617 Conversion
74Dusted
11-03-2014, 08:24 AM #5
I didn't see a tweaking/modding thread by OM616, maybe I'm looking in the wrong spot.
Not in a particularly big rush, I need to put the gas tank and bed back on my '92 D50 4x4 (huge D50 fan, they've always been my go-to vehicle of choice for reliability, mileage and modifications).
I figured with the '84 D50 and '92 D50 it would give me 2 reliable 4x4's to fall back on while I work potential bugs out of the OM617 Dakota. Learned a long time ago to have a backup vehicle when you start going into uncharted territory of engine swaps
EDIT : looks like I'll be jumping straight into the Manual Transmission conversion at the same time as the OM617 swap. A friend of my dad's, who owns a junkyard offered me my pick of a complete 5-Speed setup (transmission, bellhousing, flywheel, transfer case, driveshafts, clutch/brake pedal setup, etc) from a 4x4 Dakota of my choice, for $200.
So I'm going to fabricate an OM617 to Small Block Mopar Adapter, I'll machine the flywheel to fit the OM617. The only thing I probably won't be able to handle is balancing the Mopar Flywheel to match the 617. I'll farm that job out to the performance shop that machined the crankshaft in my 6-71 Blown Duster. Unless the 617 is Neutral Balance/Internally Balanced, in which case I could use a 3.9L/273/318/340 Mopar Flywheel.
Anyone know if the 617 is Internally Balanced/Neutral Balance, or External Balance?
This post was last modified: 11-03-2014, 04:00 PM by 74Dusted.
'92 Dakota 4x4 : OM617/Auto/205
'84 D50 4x4 : 273/727/100/203 (former turbo diesel truck)
'73 Duster : Roots 6-71 Blown 340/833
74Dusted
Messages In This Thread
'92 Dodge Dakota : OM617 Conversion - by 74Dusted - 10-31-2014, 08:25 AM
RE: '92 Dodge Dakota : OM617 Conversion - by Simpler=Better - 10-31-2014, 09:37 AM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 10-31-2014, 01:15 PM
RE: '92 Dodge Dakota : OM617 Conversion - by Simpler=Better - 10-31-2014, 01:26 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 11-03-2014, 08:24 AM
RE: '92 Dodge Dakota : OM617 Conversion - by SurfRodder - 03-01-2016, 10:50 PM
RE: '92 Dodge Dakota : OM617 Conversion - by Petar - 11-03-2014, 05:14 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 11-03-2014, 06:20 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 11-05-2014, 10:05 AM
RE: '92 Dodge Dakota : OM617 Conversion - by MFSuper90 - 11-05-2014, 01:51 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 11-05-2014, 02:43 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 07-22-2015, 09:58 PM
RE: '92 Dodge Dakota : OM617 Conversion - by Simpler=Better - 07-23-2015, 01:01 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 07-23-2015, 09:24 PM
RE: '92 Dodge Dakota : OM617 Conversion - by Simpler=Better - 07-24-2015, 12:31 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 07-24-2015, 10:45 PM
RE: '92 Dodge Dakota : OM617 Conversion - by MFSuper90 - 07-27-2015, 09:35 PM
RE: '92 Dodge Dakota : OM617 Conversion - by MFSuper90 - 01-21-2016, 06:50 PM
RE: '92 Dodge Dakota : OM617 Conversion - by 74Dusted - 02-26-2016, 03:12 AM
RE: '92 Dodge Dakota : OM617 Conversion - by MFSuper90 - 02-28-2016, 10:58 AM
 6 Guest(s)
 6 Guest(s)
