MTUPower
sonic wagon man
w126 first gen on a w123
MB w123's ) all have solid rotors. I've had two cars that had small issues with the calipers sticking and then the fluid "boiled" and I had excessive brake fading. That can be scary. I've found out that the first gen w126 (280se/l, 380se/l and 500se/l EDIT- and on the 300sd) calipers and rotors can be swapped directly into a w123- it's plug and play. You must swap both the calipers AND rotors. You will not get more braking power but the w126 is vented and the w123 is solid- so you will have more cooling- less chance of brake fading....
Here is the w123 rotor
and here is the w126 rotor
Better braking is needed when you have more HP....
1984 300TD altered IP/underhood IC/altered boost/AAZ's-265's@150bar/w126genII brakes-wheels/vogtland springs/egt-boost gauges/Bosch h-4's/AMG rear effects....and more to come.
| 03-01-2008 10:13 PM |
Re: w126 first gen on a w123
It is also found on the Diesel W126 models.
![[Image: Dieselfuelforlife.gif]](http://members.cox.net/lnewcomb99/Pics/Dieselfuelforlife.gif)
| 03-02-2008 05:11 AM |
TheDon
Plus you do have a wider option of brake discs. Brand wise (Brembo), as well as cross drilled and slotted.
I discovered this when my parts guy sent me W126 discs by accident(they were brembo's.. but a name is a name)
| 03-02-2008 10:11 PM |
If you don't want to go the used parts route, you can order rebuilt calipers and new rotors and use your old calipers for the core charge.
| 03-03-2008 06:53 AM |
TheDon
another cool option is with the bigger(later gen) w126 brakes you also have the option of Zimmerman cross drilled rotors...
| 03-16-2008 12:11 PM |
pgringo
i would not go with cross drilled. they are prone to cracking. even high dollar cross drilled end up cracking. i know a porsche club track racer who claims to have seen many. slotted and maybe cryo hardened is the goods.
| 03-17-2008 02:41 AM |
kamel
RE: w126 first gen on a w123
AFAIK, they are the same as the 123, just larger. It has been over 8 months since I seen my calipers.
| 04-23-2009 01:11 AM |
(08-19-2009 06:47 PM)DeliveryValve Wrote: So you'll need to get the spindle/steering knuckle, rotors, backplate and calipers. Maybe the lines if they look new.
You shouldn't need the spindles. Just the rotors, calipers and back plate.
You'll also need at least 15" wheels for them to fit.
| 08-19-2009 06:56 PM |
(08-19-2009 07:29 PM)willbhere4u Wrote: I think the backing plates are the same at least they where on my w123 and w116
For the wider genI W126 rotors they are, but Motorhead got a set of larger diameter genII brakes instead.
| 08-19-2009 08:58 PM |
