Board Rules |
| Please review the board rules : http://www.superturbodiesel.com/std/thread-2151.html |
Tuning
Engine
High revving diesels vs. low revving diesel engines
Thread Rating:
- 0 Votes - 0 Average
- 1
- 2
- 3
- 4
- 5
| Author |
Message |
Lance Carbuncle
Hey everyone,
I have spent the better part of my life building and racing gas engined vehicles, but the diesel performance and theory is totally new for me (and the reason I am so interested in learning it)
Before I came here, my knolwedge of diesels was limited to my 5.9 Cummins powered truck, transport trucks, and various industrial diesel powered deep sea fishing boats I have worked on and fished on. Redlines at 3,000, and cruising at 1,500-2000 at most. My Cummins Dodge with six speed and overdrive splitter is happily running down the road at 1300rpm at 65mph and can pull mild grades like this when not towing. it has around 350 hp, and 675 pounds of torque.
Now I find these Mercedes engines diesels are revving to nearly six grand and happy cruising all day at 3,000.
I also noticed from mantahead's' challenge thread also, that the torque seems much more in line with a gasoline engine built for torque produces..... a bit more than the horspower rating..... where a Cummins typically produces twice the peak torque numbers as horsepower, and at half the rpm.
So can someone tell me what makes the engines work so differently? Is it all timing and camshaft? Combustion chamber design? Stroke? Can you build a low revving mercedes OM617a or OM603/606 turbo engine to make torque like a cummins for off road truck use?
Thanks, Allen
Thanks!
| 11-24-2011 02:20 PM |
Lance Carbuncle
RE: High revving diesels vs. low revving diesel engines
willbhere4u, thanks for the great explanation, that makes a lot of sense.. I have never looked at the heads of engines with the different types of injection. I didn't realize it was a difference in the head, I thought it was just a different kind of pump or delivery pre engine..... now it makes sense when I look at the OM352 engine, as I wondered why it didn't rev. I see it is direct injection. I love to learn new things!
So did Mercedes make any small (2.5-3 liter) non electronic, non common rail, direct injection diesels?
| 11-24-2011 09:11 PM |
majesty78
(11-24-2011 06:57 PM)willbhere4u Wrote: Only IDI / Indirect injection diesel car rev this high easily. The prechamber with the glowing red hot ball can start the burn as the fuel is being injecting before TDC when the cylinder is completely compressed like a gas engine!
DI/ direct injection has to wait till after TDC when the air is hotter to start injecting. So it has a shorter power cycle that's not very effective after 3000rpm
at least that's how I under stand it
No, direct injection (TDI ,CDI) also starts BTDC under WOT, about 20-30° depending on engine type....
Mercedes Benz W210 E-Class 320CDI, lowered 2.5", 18" AMG wheels, Decat, EGR removed, Tumble flaps removed, C30 AMG injectors, 400kpa MAP, Custom GT2566XTV turbo, SW tweaked to 300+hp/750Nm
| 11-24-2011 10:27 PM |
User(s) browsing this thread: 1 Guest(s)
