RE: SLS Removal Thread
(06-26-2009 04:58 PM)GREASY_BEAST Wrote: What's the preferred method of replacing the SLS with just good old fashioned shocks and springs?
Selling it for a 300D.
I have never seen anybody happy after removing the SLS.
![[Image: Dieselfuelforlife.gif]](http://members.cox.net/lnewcomb99/Pics/Dieselfuelforlife.gif)
| 06-26-2009 05:15 PM |
Closer to 400lbs since the fuel tank sits behind the rear axles instead of above as it does in the sedans.
| 06-26-2009 07:50 PM |
(06-27-2009 07:01 AM)GREASY_BEAST Wrote: mercedessource is a ripoff has a kit... Anyone heard of it?
Yes, and I know of their shady business deals and their very high prices.
| 06-27-2009 07:03 AM |
Taxis had it and the sedan has all the same mounting points as the TD for SLS.
| 06-28-2009 03:02 AM |
GREASY_BEAST
Okay. So I've learnt my lesson about mercedessource is a ripoff .
Email 1:
Quote:Hello, I may be interested in your SLS replacement kit. Both my SLS shocks
blew and I am thinking about deleting the entire system. Are the springs
custom made or are they standard equipment on another Mercedes vehicle?
Also, I will not require the sway bar end links because I just installed a
set 4 days ago. What will the kit cost without those? Could you give me an
idea what shipping would be to XXXXXXXXXXXXX? Thank You.
Response 1:
Quote:HI GREASY_BEAST -
The springs are made by Lesjofors and they are a Mercedes factory spring from another year and model -
I could deduct $ 15.00 for the rear sway bar links from the kit
Shipping to Vermont would be $ 45.00
Email me back and let me know if you would like to proceed with an order!
Cheers,
sales@mercedessource is a ripoff .com
Email 2:
Quote:You sell the same swaybar endlinks on your website for $19.95. Why is it that you can only deduct $15 if you don't include them? Also, what brand and type of shocks are included in the kit? Could you provide me with the part number for the springs as well? Which carrier do you ship with? I'm sorry to be a pain, and I really do want to purchase this kit from you, but it rubs me the wrong way to be gouged, even if it is a matter of only $5. I hope when you provide me with the information I have requested I will not see more evidence of this.
A day passes.... no response.
Email 3:
Quote:Hi,
I am interested in doing business with you. If you provide me with the part numbers I've requested, and I can ensure that your prices are competitive with other retailers, then I promise to buy your product. Please let me know if you are interested in selling me this kit. I am interested in buying it if you can come through on your end.
Response 3:
Quote:Thanks for your inquiry -
I am sorry but we are no longer offering this kit for sale
Email 4:
Quote:Hello XXXXX,
If you are no longer offering the kit for sale then why did you offer to sell it to me?
Response 4:
Quote:We recently made a decision this week to focus our attentions on repairing the existing system so we decided to no longer offer the conversion kit - We are going to be releasing a full length diagnostic manual on the SLS and many repair kits for things such as the leveling valve and the hydraulic pump
SO. I want to make this happen. I will be searching through lists of springs just as soon as I get them, and I'll be sure to post part numbers here when I find them. I'll be using Bilstein HDs from a W123 Sedan. And I won't be paying any $400 either.
(This post was last modified: 07-02-2009 12:47 PM by GREASY_BEAST.)
| 07-01-2009 08:06 PM |
MB TECH
sick wagon
I removed my SLS rear suspension on my TD, I installed used sedan springs with the thickest upper mount (mercedes makes 3 different thicknesses) and then installed some NAPA shocks.
I also installed some rubber coil spring spacers in between the coils to give it an extra inch of ride height.
The springs were free from my parts car, the shocks were only $50 each, the mounts were around $20 and the spacers were
$20
The car handles awesome and I dont have to worry about the SLS leaking and whatnot
Also you have to make a block off plate for the suspension pump, some bulk steel and universal paper gasket material works good for that
1983 300TDT
Mechanical: GT2359v turbo, front mount air to air intercooler, 1600 cfm electric fan, aluminum radiator, SLS removed, chopped front springs, custom side exit exhaust, Moroso muffler, aftermarket engine oil cooler.
Cosmetic: 19" wheels (285/30R19 rear, 255/35R19 front), pillar mounted EGT and boost gauge, grant steering wheel, custom grille, 4" functional cowl induction hood, tinted window, side trim removed.
Mechanical: Rapid glow plug kit
Cosmetic: Exterior color changed to silver, Interior dyed black, 18" 219 wheels.
111 chassis undergoing full restoration, body to be dipped soon. Mustang II IFS on the way as well as big brakes, debating over 560 117 engine or 606 diesel.
| 07-06-2009 01:16 PM |
MB TECH
sick wagon
That could be, but if I remember correctly the 140 springs are taller than the 123 springs (at least the ones I have replaced) and if you were to mash them under a 123 they might become coil bound. I will try to do some research and see if I can come up with some dimensions for those springs.
1983 300TDT
| 07-06-2009 09:38 PM |
SurfRodder
'83 300D **4 speed ** stainless flex oil cooler and brake lines ** powder coated valve cover, oil tower, and injection lines ** manual climate control ** better stereo ** homemade intake and monstercraftsman oil separator ** EGR Delete ** Euros and clear corners ** 4 light brake mod ** Vogtland 50mm drop front springs ** Lesjofors S600 drop rear springs ** 16" rims ** late model 126 brake spindles, rotors and calipers ** full suspension rehab ** Bilstein HDs ** AL129X alternator ** 1/0 starter and charging cables ** late W126 front seats and rear seat back
'87 Cherokee w/4.9L stroker motor
'94 Stealth TT -track car to be
'96 Mitsu 3KGT VR4 bit a show lotsa go
| 07-07-2009 05:02 PM |
Telecommbrkr
Soon to be mod'ing......
| 07-09-2009 08:42 PM |
MB TECH
sick wagon
you must let me know how it works out, I would like to see what the alternatives are to my kobble job of a rear suspension
1983 300TDT
| 07-10-2009 02:14 PM |
85-300Dt
| 07-14-2009 07:04 AM |
85-300Dt
(This post was last modified: 07-14-2009 11:41 PM by 85-300Dt.)
| 07-14-2009 09:47 PM |
Floridacyclist
Am I the only one keeping this page up and reloading it about once an hour to see if it's been updated? LOL
| 07-25-2009 01:40 PM |
MB TECH
sick wagon
Try to send a pic of the side view of the car when you get a chance, im curious to see the ride height.
1983 300TDT
| 07-29-2009 11:00 AM |
GREASY_BEAST
(07-28-2009 01:29 PM)mbkomfort Wrote: Hi all! Coupe and Sedan rear shocks, both normal and SLS, have a different lenght than the Wagon SLS shocks so they are not interchangeable.
As most of you belive that the SLS shocks are just simle hydraulic struts i won't argue on that, but i'd sure like to
I had to jack the 300D shocks into position, but with a little coaxing they went in fine. However, the ones I used were from a junk car and they seem to be inadequate. I'll get Bilstien HDs and put them in. The ride height is a bit too high so I'm going to get the shortest available shims and install them along with the shocks. Otherwise, the springs are not too bad overall. They are a little too stiff, that is, the ride is certainly harder than the SLS. It is not terrible, just different. HD shock absorbers and ride height correction should take the bounce out of it. I'll upload a pic sometime soon.
As for shock absorber height, I'll look into finding ones that are better suited, or consider raising the shock mounts. Any ideas?
| 07-30-2009 08:04 AM |
MB TECH
sick wagon
You want to be careful on adjusting the shock mounts or using aftermarket shocks, I have monroe shocks in mine and when I put it on a lift at work you can play the rear brake hoses like a guitar. so limiting straps were reqd. But definitely keep up the posts on what you decide to do about that. Also one question how far apart are the coils on the spring from each other when it is on the ground?
1983 300TDT
| 07-30-2009 08:28 AM |
