STD Other Projects MB 300SD oldtimer
MB 300SD oldtimer
MB 300SD oldtimer
  • 4 Vote(s) - 3 Average
Pages (3): Previous 1 2 3
_siim_
W201STD
21
07-22-2012, 09:51 AM #101
This kind of LSD does not work,I test it,one wheel on the asphalt and the other on the gravel,it took soooo long time to get away Big Grin
It was same,Elbe system from Estonia Tongue
_siim_
jeemu
457
07-28-2012, 03:36 PM #102
(07-22-2012, 09:51 AM)_siim_ This kind of LSD does not work,I test it,one wheel on the asphalt and the other on the gravel,it took soooo long time to get away Big Grin
Hi Siim Smile
My fried installed that lock on ASD diff and it worked just fine.
Before installation i coated parts and he drive it bout 50tkm wih no problems.
[Image: _smaller.jpg]
jeemu
Hi Siim Smile
07-28-2012, 06:27 PM #103
What is the whole purpose of the LSD differential? I'm confused
Never mind I got it, limited slip
This post was last modified: 07-28-2012, 06:31 PM by sassparilla_kid.
300SD_KY
super turbo diesel
121
08-11-2012, 10:30 PM #104
Making the old new again. Love this build.
300SD_KY
JTY
08-16-2012, 04:17 PM #105
I had no problems with Elbe LSD kit, worked as promised, maybe you installed it wrong Huh
Too little clamping force Huh
- MB r129 500SL AMG (JDM) -94
- MB w123 250E-TT (JDM) -85
JTY
Cole
It's as easy as 1 - 2 - 3!
21
08-29-2012, 09:30 AM #106
this thread is spectacular, wow what an impressive automobile, the quality of work is just staggering
i'm so lost with all that incredible work, jesus. just wow.
1982 300TD - Wilber
1985 300TD - Ol' Blue (parts car)
1984 300D - Black Beauty (parts car)
various OM617 and 617A parts engine
"You have to realize that this is a DIESEL and you have a gasser for starters - what works for you will not necessarily apply to me. I for instance could run 35 pounds of boost and probably more and your engine would be a block with melted pistons. "
-Rudolf Diesel
Cole
1982 300TD - Wilber
-Rudolf Diesel
thegooch27
09-12-2012, 06:56 PM #107
(01-04-2010, 03:59 PM)JTY Exhaust manifold done by KKDMotorsport
Turbo and manifold installed, looks much better than the original mini turbo Smile
[Image: p1020337.jpg]
[Image: p1020329.jpg]
Around April 2009 it was time for first start.
Everything worked okay and the engine started nicely.
[Image: p1020342.jpg]
Video at youtube
I had some other projects whole summer and the 300SD was standing in garage.
But around December 2009 I decided it was time to re-start the project.
Everything else was ready, only intake manifold was missing, so it was time to start build and custom intake. I had in mind to use original turbo intake but noticed quite quickly that it was bad idea Dodgy
So i started from scratch:
[Image: p1030824.jpg]
[Image: p1030826.jpg]
New intake fits nicely with new exhaust manifold:
[Image: imusarja-final.jpg]
[Image: hukkis1-m.jpg]
As the turbo was without wastegate I installed and external wastgate:
[Image: hukkis3-m.jpg]
Here are the latest shots from last weekend, made some thermal wrapping around manifold and few finishing touches:
[Image: sarja1-m.jpg]
[Image: sarja2-m.jpg]
Engine works nicely with boost, needs few things before going to dyno.
Also going to install my latest version of supermeter:
[Image: p1030334.jpg]
Very cool stuff indeed! With your supermeter, do you monitor TPC? Can you give a little info on your sensors like where you are mounting them and what kind you are using?
This post was last modified: 09-12-2012, 06:59 PM by thegooch27.
thegooch27
Video at youtube
10-24-2012, 10:43 AM #108
Beautiful!
Did you bore out the ports on the head?
How much was that amazing exhaust manifold?
Beautiful!
JTY
11-02-2012, 05:04 AM #109
(10-24-2012, 10:43 AM)Simpler=Better Beautiful!
Yes the heads was ported pretty extensive also valves was changed and modified.
Custom exhaust for OM617A is around 500-600euros at KKD
Mine was first one made for OM617 so it's the prototype Big Grin
(09-12-2012, 06:56 PM)thegooch27 Very cool stuff indeed! With your supermeter, do you monitor TPC? Can you give a little info on your sensors like where you are mounting them and what kind you are using?
Thanks Big Grin
TPC stands for what Smile
I'm using custom sensors that are built myself, i use special
industry grade extra fast temperature sensors, same with pressure and exhaust. IAT is mounted after cooler before manifold inlet, EGT/EXP is mounted right before turbo, OILT is before oil cooler and TRANST is before trans cooler.
This post was last modified: 11-02-2012, 05:08 AM by JTY.
JTY
Thanks Big Grin
11-07-2012, 09:34 AM #110
Would you be kind enough to share any photos/ details of the head work you did? I went easy on my head, the cutaway diagrams I've seen show really thin walls in the head.
peter
11-25-2012, 12:51 PM #111
(06-13-2010, 04:56 AM)JTY Some update, I installed a LSD unit in the diff
Few shots of the LSD unit:
[Image: p1040914.jpg]
[Image: p1040928.jpg]
Empty diff case
[Image: p1040932.jpg]
Looks good
[Image: p1040933.jpg]
Middle shaft seems to be in good shape
[Image: p1040934.jpg]
Spiders are pretty bad :roll:
[Image: p1040935.jpg]
LSD unit installed
[Image: p1040937.jpg]
Gear ratio
It's no much more fun to drive and it's very stable when you do an fast launch.
does this LSD unit fitt in all w126 differentails??
i would like to get one and to know where you got it from.
peter
i found it already
http://elbe.ee/products/drivetrain/lsd
This post was last modified: 11-25-2012, 05:03 PM by peter.
94´E 300D ,white , black leather interior, om606.910,MB 5speed shifter
peter
Empty diff case
Looks good
LSD unit installed
Gear ratio
peter
i found it already
haromaster87
1984 300D Turbo
10
11-27-2012, 03:06 PM #112
Love this! Hope I can do something similar with my engine one day!
haromaster87
JTY
01-09-2013, 10:57 AM #113
(11-25-2012, 12:51 PM)peter
Empty diff case
Looks good
LSD unit installed
Gear ratio
peter
i found it already
Yes it fits all, you can get seperate units for 124 etc.
(11-07-2012, 09:34 AM)Simpler=Better Would you be kind enough to share any photos/ details of the head work you did? I went easy on my head, the cutaway diagrams I've seen show really thin walls in the head.
Okay i will try to find the pics from the port job. Should be somewhere on my backup drive Smile
In my head there was plenty of space to make the channels bigger, original channels are very small with tight curves Sad
This post was last modified: 01-09-2013, 10:59 AM by JTY.
JTY
Empty diff case
Looks good
LSD unit installed
Gear ratio
peter
i found it already
mantahead
01-13-2013, 04:21 PM #114
can't believe i haven't seen this before, that is one nice car. Sweet.
mantahead
JTY
01-17-2013, 10:33 PM #115
(01-13-2013, 04:21 PM)mantahead can't believe i haven't seen this before, that is one nice car. Sweet.
Thanks Big Grin
JTY
Thanks Big Grin
02-18-2013, 12:51 AM #116
You have a US speedometer! I want one that goes that high!
JTY
02-24-2013, 01:41 AM #117
(02-18-2013, 12:51 AM)Captain America You have a US speedometer! I want one that goes that high!
Yes it's a 300SD and it was only sold in US Big Grin
Get the higher speedometer from some old 300SD.
JTY
kmaser
Turbocharged G-Wagen
125
03-09-2013, 07:18 PM #118
For the oil supply to the turbo are you feeding it full engine oil pressure or is the stock 2mm restrictor hole still in the system. I had an MP R444-2 and without the restricted it forced oil past the seals turbine and compressor side, I have some other issues to sort out as well but I need a new turbo as a result and want to go bigger than I had with my (6.5mm elements) I think the stock exh. Manifold is too restrictive, I don't see yours on the kkd website so do you know if its available still?
kmaser
JTY
03-10-2013, 01:34 AM #119
(03-09-2013, 07:18 PM)kmaser For the oil supply to the turbo are you feeding it full engine oil pressure or is the stock 2mm restrictor hole still in the system. I had an MP R444-2 and without the restricted it forced oil past the seals turbine and compressor side, I have some other issues to sort out as well but I need a new turbo as a result and want to go bigger than I had with my (6.5mm elements) I think the stock exh. Manifold is too restrictive, I don't see yours on the kkd website so do you know if its available still?
Yes it's done with full engine oil pressue, with custom steel braided hose and AN connectors to get maximum oil flow. Had no issues with the seals and this hose set was done & approved by Master Power expert/imported Anton Murola from hevosvoima.com Smile
Maybe you had some other issues with the system, like really restricted oil return as that's going to cause seal problems if pressure side flows too much. I made oil return of big copper pipe to have as little as possible restriction on return side (this was also consulted with Anton)
My KKD manifold was first of it's kind a prototype manifold, you should ask Kalle to build one for you as he should still have the jigs for it.
JTY
Jonas94
12-10-2016, 05:35 PM #120
What happend to your carSmile?
Jonas94
dashaby
01-06-2017, 11:05 AM #121
Beautiful car! Would love to see it imported to the states for an adventure.
dashaby
05-18-2017, 01:50 PM #122
How's the LSD holding up?
JTY
06-10-2017, 12:43 AM #123
(12-10-2016, 05:35 PM)Jonas94 What happend to your carSmile?
I sold it to an friend, still rocking  Big Grin
Have since moved to E85 cars, no diesels anymore in our family Tongue
JTY
JTY
06-10-2017, 12:46 AM #124
(05-18-2017, 01:50 PM)winmutt How's the LSD holding up?
It did'nt hold for long, I needed to change even stiffer springs and after that
I got the grip I wanted. No serious problems after that, just need to use quality
oil in the diff ( I use MAG1 85W-140 diff oil)
JTY
 7 Guest(s)
 7 Guest(s)
