New Project - Skunkwerks EM9D
I finally put in a thermostat and replaced the upper radiator hose! And now that its not overheating at speeds above +75mph / running to cool below -70mph it feel like it has more power!
When I did that run I had a 1/8 vacuum/boost leak and turbo injectors that where nailing like caterpillar! once I fixed the boost leak and put the stock injectors back in it ran a lot beater
I could probably break 60mph in the 1/4 maybe even get it down in the low 20's with luck on my side
I still have a bad nailing at idle some times depending on what temp the engine is running and absolutely no smoke!
My next goal is to lengthen the spring on the lift pump and switch my return /feed lie to see if that helps with power
When the engine is cold it has almost not enough power to move! once it runs for 15min it starts moving pretty good!
