09-17-2010, 06:55 PM
#438
(09-17-2010, 05:29 PM)Rudolf_Diesel As far as EMP, it is either equal to or a few lbs. higher then the boost pressure and it is also lower depending on the load - yes I have experienced all of these scenarios. I believe it meets or exceeds my expectations for back pressure in the exhaust system.
If you ever get a chance to play on a dyno get a plot of both your pressures vs power and torque. Depending on what your after, you can adjust the point at which you make more boost than backpressure and the point at which you have the highest ratio of boost to back pressure by playing with the AR ratios of your turbine and compressor housings. A turbo gives maximum benefit at the highest ratio of boost to back pressure.
A VGT effectively allows you to change the AR ratio of the turbine on the fly which is why they are so great.
Since you are intercooling that means a lower boost pressure would deliver the same amount of air. However I don't think that your cooling enough to cram the same amount of air at just 3psi. Also remember that also since your intercooling that your EGTs would be lower than stock if you were getting the same amount of air. If your getting the same EGTs as stock with less air you will be subjecting some engine components to higher peak thermal loads than normal. To what degree this offsets benefits of lower pressures I'm not sure of.
I get 6psi at about 65 and 9psi at 80 like Captain America with my car too. More boost at 65 would probably get you better mileage. Of course I don't think mileage is your main goal.
