Clutch for OM606 in -88 124 Mercedes
You can go over the 9.2mm recommended to increase the clamping force of the pressure plate, I run an organic sprung plate so it needs a little help to hold the torque load. It does make the pedal a little heavy though.
That's why I wouldn't machine the rear of your flywheel, those extra 2mm would allow you to do the same if you need to.
The downside is that the clutch wont slip but it will shatter.
