Clutch for OM606 in -88 124 Mercedes
Today i (finally) did some more measuring, i did as Simon suggested and compared to the sprinter kit pressure plate, and the difference is about 4mm on the heigt of the clutcplate fingers if i was to retain the height of the clutcplate surface on the flywheel, this kind of makes sense, with 4mm extra clearance we are quite close to the 5mm i was thinking of machineing off since my previous measurments ended up with zero clearance.
I also double checked the position of the starter ring gear, and it is indeed 2mm further back then the sprinter flywheel then with the om 603 one.
There seems to be quite a big difference between the Valeo sprinter flywheels and the Borg and Beck kit i have apparently, i am thinking the Valeo propably is much higher quality and precision.
I am thinkin i might machine 2mm of each side of the flywheel, that way i get the clearence i need and the starter ring gear ends up where it was before, what do you think?
