Om 606 Delivery Valve Part Number
(05-17-2020, 12:04 PM)zeemanLike the shims on the MW-pump? I know there are two styles, split shims that can be inserted without removing the barrel, and one-piece shims, that require barrel removal. I have the PNs for the thicknesses of those too. I wonder if there are complications will the barrel fill port lining up when shimming, as the M-pumps weren't shimmed stock.nastalaI know Luke at Dieselpumpuk uses shims instead of changing the roller, much easier to do. He has a video of it very interesting.dieseltorque Thanks! Can you see in catalog part numbers for pump element lift rollers as well? Those may be with different outer sizes as used for phasing of elements,,,,I looked up the PNs for the OM605.912 (PES5M55C320RS202) and OM606.912 (PES6M55C320RS204), and they share the same 25 roller sizes. Looking at the part/prod use, a ton of 4, 5, and 6 element flange-mounted M-pumps use these same tappets. All the pumps that share these rollers have "C320" in the name, but not all pumps with "C320" in the name share these rollers, some are 3 cylinder.
1 410 300 207 14.40mm
... (check earlier reply for list, too long to quote over and over again)
1 410 300 260 15.78mm
