OM606 Turbo Selection for Truck application
(05-15-2020, 08:52 AM)jav1 No - I didn't take it as snarky at all... I didn't know the "roll eyes" thing either so ignorance is bliss?
On the table thing - that helps because in the table I referenced - "fuel request table"-, which is the main one I've played with to tune my fueling, I have values from 50-90 in my top values row which corresponds to- 100% throttle position. I'm still not 100% understanding the relationships between "ALL" the tables and it doesn't help that being rather new, I struggle to find certain things as referenced because the names used don't always match up perfectly nor are they all under the same "tab" in the software.
For example- I can't find a "rack position request table" under the tables tab... BUT- I do find a "simple rack position request f (fuelrequest)" under the rack control paramters tab... which I surmise is the table you are referring to but, not knowing all the tabs inside and out- I second guess things when the names used don't match up with the software names 100%?
In my pea brain from what I gleaned from Baldur- the "simple rack position request f (fuelrequest)" parameter defines how the fuel injection rack moves in response to fuel request values (0-100%). That parameter should have a max value of 2100 according to Baldur, as that 2100 number represents (approximately) the "full- bottomed out" rack travel value on most stock 606 pumps. But now- if that parameter establishes the relationship between rack command value and fuel request values, I don't understand why the parameter has correlations from 0.0 - 250 when my maximum fuel request value is 100??? In my tune- I set "simple rack position request f..." values at 260,740,920,1390,2100,2100,2100,2100. with the first 2100 value represented at 100 and all values above 100-250 still having the 2100 rack command value. Is that right? I think so but I'm not 100%??? Does this parameter suggest we could have fuel request value up to 250 in the fuel request table?? I'm sure Baldur has a good reason for doing this but not knowing what he knows, it causes me to question if I really understand how to fully use all of the controllers capabilities or if I'm doing it right?
