OM606 Turbo Selection for Truck application
(05-14-2020, 10:21 PM)X Double Dot(05-14-2020, 08:01 AM)jav1 How did you get to 100% fueling = 83ul of fuel? I do still have the stock (6mm) pump.
83ul is just what is in my fueling table for 100% throttle pedal position. What max fueling and/or rack position are you commanding?
to your comments on the higher egts, yea i've always been curious as well if the higher flowrate, at presumably the same temperature has something to do with it. I wouldn't necessarily think so. that would have to mean that something is cooling off your probe pretty quickly. As long as it isn't right on the ID of the manifold I wouldn't think this would be the case.
Will be very interested to hear how the gta2359 compares with respect to spool as well as egt/performance at higher rpm. Hopefully you will keep us posted on what you find
