STD Other Projects Low Budget Hight Boost: 300HP OM605 Diesel drift car build for 500€
mmetzdavid
01-20-2020, 03:38 PM #1
Hello everyone!
So, I want to build a budget 300+ hp OM605 W202, good in everything but not the best in anything from less than 500€, incl. the car.
I already have purchased the base (rust free W202 C250 turbodiesel, with manual gearbox and some issues as it was mixing oil and coolant, but that I already fixed), a bigger turbocharger (Garrett GT2260V, the later electronically controlled unit from E60 BMW 530D, already cleaned and sandblasted it), Dieselmeken 75L3 (7.5mm) elements (BIG thanks for Erik from Dieselmeken for helping me out with those, more on this subject later), and I had a few Bosch M pump cores to build a mechanically governed pump for it. The turbo's VNT actuator is driven with the stock MAP sensor of the car, and a programmable Arduino micro controller, as it is cheaper than a pressure actuator and I am sure it will work MUCH better. That's already done too, just need some testing after I mount the turbo.
I want to make a Youtube series on the build, is anyone interested?
mmetzdavid
Hello everyone!
84 GTI
01-21-2020, 07:55 AM #2
Good luck with the project and yes please do a Youtube series if you can
84 GTI
Repetitio
01-25-2020, 11:59 AM #3
Nice project i´m hyped! please youtube series yes!
Repetitio
mmetzdavid
01-31-2021, 07:05 AM #4
So it took much longer than I expected, but here is the first episode. In a few hours it will be available in higher definition aswell.
https://www.youtube.com/watch?v=qESTOrA4e1o
mmetzdavid
