DIY element swap
DIY element swap
(02-04-2019, 08:37 AM)mmetzdavid Just wondering, never been there, but what if you measure exactly (very precisely) the distance set-up on the EDC pump between the element connections on the rack (where you fine-adjust the rotation of elements compared to a given rack position) and after the swap you adjust these distances to be exactly the same on the M pump? And after, it is just a question of fine adjustement of the rack itself, no need to adjust elements between themselves. Oh, and of course you must put elements in the order they came out (I mean every element for the cilynder it was used for, don't mix them up). This should pretty much balance the elements between themselves, if they were correctly balanced on the EDC pump to start with.
