Common rail diesel discussion thread
(05-26-2020, 10:36 AM)SurfRodderSurf - Are you putting the motor in the 123 or the 124? I think I am finally replacing the 617.(04-13-2020, 06:16 PM)baldur The OM648 and OM613 are almost identical. The 648 has an upgraded high pressure pump, an electronic VGT actuator and depending on the year it can have some more emissions kit like an electronic throttle body for better control of EGR flow. The injectors are interchangeable although I believe the 648 injector flows more fuel.Awesome. I will be purchasing one later this week to run my OM648. I have full '05 e300d engine harness and a matching set of security / ecu parts but was not looking forward to working with it. Once I heard about your effort here nearing completion, I decided to wait. Only problem now is getting to this project soon enough. I have several in front of it that I hope to complete this summer
You absolutely could run an OM648 on an OM613 wiring harness if you had a 613 wiring harness on hand, you would need to make some minor modifications. As it turns out the mass airflow sensor on the OM613 uses the same connector as the turbocharger VGT actuator on the OM648 and the mass airflow sensor is not needed by my ECU so that part of the loom can be repurposed.
You could also just snip the ECU end off the 648 harness and follow the step by step instructions I prepared for attaching new connectors to run my ECU on the OM648. Have a look at https://controls.is/manuals/did1.pdf appendix E covers the OM648 wiring step by step.
In any case, thanks again for making this happen.
