Common rail diesel discussion thread
The stock turbo is good to for 1.8 bar at mid RPM and 1.6 bar at higher RPMs on the OM648. This will max out the stock 2.5 bar MAP sensor. If you go with a 3 Bar MAP sensor you should be getting close to 300hp. You will definitely want to monitor EGTs at this power level.
