Common rail diesel discussion thread
(07-29-2019, 11:04 PM)atypicalguy(05-12-2019, 06:03 PM)baldur(05-11-2019, 06:35 AM)madmog Baldur, I'm curious, are you planning on having any out-of-ordinary-readings cause a limp mode event? Or, if not limp mode, will out-of-ordinary-readings toy your ECU create an OBD type message, light a warning light or whatever?
Or is it simply a case of when something isn't running correctly, a failed MAF sensor or whatever, it's tracked down in the old fashioned way?
Thanks
Yes there will be a comprehensive set of self diagnostics on there including OBD messages.
You could easily fund development of this using kickstarter or Patreon or some such mechanism. I think there are several to choose from now.
Thanks
