STD Tuning Engine OM606.962 Valve Float @ raised boost?
X Double Dot
01-13-2022, 03:30 PM #29
curious what all came out of this. Did you try the stiffer springs or the large exhaust housing turbo? Considering adding a egp gauge to my setup to confirm i'm not running into a similar issue
X Double Dot
Messages In This Thread
OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 01:23 PM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 12-19-2018, 01:50 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 02:13 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 03:00 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 03:12 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 03:22 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 03:40 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 04:03 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 04:18 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-19-2018, 04:36 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-19-2018, 09:18 PM
RE: OM606.962 Valve Float @ raised boost? - by firen456 - 12-20-2018, 01:08 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 08:13 AM
RE: OM606.962 Valve Float @ raised boost? - by firen456 - 12-20-2018, 08:28 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 08:40 AM
RE: OM606.962 Valve Float @ raised boost? - by firen456 - 12-20-2018, 10:40 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 11:03 AM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-20-2018, 03:20 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-20-2018, 05:49 PM
RE: OM606.962 Valve Float @ raised boost? - by erx - 12-22-2018, 12:47 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 12-23-2018, 09:54 PM
RE: OM606.962 Valve Float @ raised boost? - by Ecto - 03-14-2019, 10:35 AM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 03-15-2019, 02:43 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 03-14-2019, 01:17 PM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 03-15-2019, 02:51 AM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 03-15-2019, 12:14 PM
RE: OM606.962 Valve Float @ raised boost? - by barrote - 03-15-2019, 03:45 PM
RE: OM606.962 Valve Float @ raised boost? - by jav1 - 03-15-2019, 07:02 PM
RE: OM606.962 Valve Float @ raised boost? - by X Double Dot - 01-13-2022, 03:30 PM
