STD Other Projects 1984 300D TURBO DIESEL Sleeper
sneakystd
10-25-2023, 08:57 AM #1
Just bought a 1984 300D Turbo Diesel in NE USA.
150K miles on the clock.
So far I have deleted both the EGR and ALDA. I feel I am getting more power in the low end but not a lot of increase in black smoke. I am able to do minor burnouts Big Grin
What is the next logical component to upgrade? I want to create custom cold air intake. I have also seen available turbo and injection pump upgrades but those are a bit out of budget at the moment.
Any tips on adjusting the gas pedal linkage? The car really has no go until about 3/4 to full throttle.
I intend to keep this thread updated with photos as the car progresses! Cheers!
1984 300D TURBO DIESEL - 149k miles - ALDA Delete, EGR Bypass
sneakystd
NZScott
HX30W 73/44mm
398
10-26-2023, 12:46 AM #2
It *should* already have the best cold air intake right from factory
I believe you left hand drive folk have a bushing on the firewall that wears causing excessive slop in the throttle linkage.
Nice car, just needs the cut and polish finished Wink
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
sneakystd
10-26-2023, 11:42 AM #3
(10-26-2023, 12:46 AM)NZScott It *should* already have the best cold air intake right from factory
I believe you are correct on the worn out bushing for the throttle linkage. Looks absolutely terrible. I am curious as to how the linkage is not binding up. Will be thoroughly going over it and replacing the bushing.
I will be putting the stock intake back on after purchasing a new filter and filter housing bushings.
sneakystd
sneakystd
11-05-2023, 09:21 PM #4
I fixed the linkage with a new assembly. Not OEM but I modified it to operate smoothly.
[Image: WptZ291]
[Image: XkhbyTZ]
[Image: xY2X0nP]
[Image: H22w8WF]
PS. How do I get images to display correctly in my posts?
sneakystd
[Image: WptZ291]
[Image: XkhbyTZ]
[Image: xY2X0nP]
[Image: H22w8WF]
