Evry mod W202. A few question for cheap tuning...
Hello,
My name is Hans, I am from germany and i am riding an old W202 C250 turbodiesel and its burning black diesel. (Sorry for the bad english)
Because of the lack of power with my special fuel, i made the evry mod with a variable resistor.
It is equipped with the 4 speed automatic gearbox, thats why i don't need to much power. But the black smoke is not very nice.
My question is this:
Can i cheat the map sensor to avoide problems if i install the turbo from a OM606?
At the moment the car drives like an accordion or like pulled on the rubber band... Because the charge pressure fluctuates.
I think about the turbo from OM 606 and convers it to pressure control, if this is possible.
Or do you think the OM 605 turbo is big enough for the automatic transmission?
I am thankful for your answers, and I know, Evry mod is not the best solution, but i don't need more then 200hp... (maybe 250? )
Best regards, Hans
Might want to check this out https://youtu.be/mkjYVfxJK9s?t=197 .
They just put a T in the line with a small hole on the end . But in their case this is necessary to lower fueling, but you should be in a similar situation with the resistor mod .
At any rate its a cheap thing to try before going to a different map sensor .
F-tune has a couple of videos on his channel regarding turbos, and suggested some for your power goal .
(07-02-2023, 11:00 AM)BeginnerC250Tur Hello,Hi
Best regards, Hans
Best regards, Hans
The idea with the switch on the gas pedal is excellent. I build it in series with the main switch for the emissions test
every 2 years, or if my wife is driving...
Can anyone recommend a turbo conversion kit to pressure control for OM 606turbo?
And maybe someone knows a inexpensive
map sensor that manipulates the values?
Best regards,
Hans
