722.6 w210 stall speed
Ok, so I finally got to opening the TC that apparently was overheating my transmission when driving on the highway, seemingly when the lock-up should have been applied. Well, to my surprise everything inside the TC was in perfect condition, clutch and everything without any signs of overheating. So I’m confussed, I don’t know how to explain the overheating when the problem went away as soon as I replaced the TC with another used one. I did not do absolutely anything else, even used the same burt oil, didn’t even refill since it was a bit low. So go figure! Any ideas?
Something else, these last few days the transmission seems to get stuck while trying to downshift, as if the TC got stuck locked up or as if a downshifting valve/solenoid was getting stuck. The transmission temp is fine though, and it wasn’t doing this when I was having the overheating problem. I hope it’s that I’m a bit oow on fluid, maybe more than a quart. I was waiting to replace the TC to change the oil...while I also try to make of my TC a diesel version, a decision I’m trying to make in a day or two.
