722.6 w210 stall speed
(09-23-2018, 09:38 AM)50harleyrider Can anyone tell me the stall speed on these trannys which were oe on the 98-99 w210 E300 TD cars? I have to buy a torque converter for my 97 F150 conversion and am struggling with the proper stall speed I should spec. I'm using the Ford E4OD transmission with Baldur's DSL1 and a tuneable Quick 4 TCU. I made the mistake of buying a Hughes low stall 7.3 diesel tc and it sucks. I don't want to go with lower gearing or shorter tires yet as that would be a fuel mileage killer and look crappy on a 4x4 truck!Your stall speed will depend on your gear ratio and tire size also. Talk to Evenglass on the forum. He used FTI Custom to build one for his Jeep Cherokee with a 700R4. He went with a 1850 rpm stall speed, talk to Greg at FTI 1-866-726-8358. You have to go with a higher stall speed with the Merc trans similar to a gas stall speed but you need the stronger internal diesel parts. You need a higher stall speed with the OM 606 to get the RPM'S up to get in the power band from a dead stop, or it will be a turd off the line. Gear ratio plays into this also, you probably need around a 3:55 to 3:73 depending on tire size to get any performance off the line with a heavy vehicle.
My patience is starting to run thin with the whole idea of an automatic in my truck. Slipping the clutch a bit or getting the truck moving with a 6sp manual with a granny 1st gear sure would be a lot simpler for spool and takeoff not to mention better fuel mileage
