STD Tuning Engine Question about OM617 pump drive
HeavyArms
06-12-2018, 03:52 PM #1
Well im making a few mods to my OM617 that im dropping into my Jeep Cherokee. One is i needed to make a delete for the factory vacuum pump. Well because im not good at leaving well enough alone i took the injection pump "dampener?" Drive apart only realize its 2 pieces and sprung. Can i lock it into place? Or do i need to reassemble it to make the engine work? And if i do have to reassemble it do i have to take the timing cover off and gear out to do it?
HeavyArms
NZScott
HX30W 73/44mm
398
06-12-2018, 11:38 PM #2
That's the "timing device" and needs to be put back together if you want your injection timing to advance properly. I've never had one apart so can't help you but think it's pretty simple as long as you didn't lose any bits!
1977 300D (ex 280) 500,000km
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
HeavyArms
06-14-2018, 09:03 PM #3
Thank you, I was hoping I wouldn't have to use it haha. now to see if I can make it go back together without taking the chain off haha
HeavyArms
NZScott
HX30W 73/44mm
398
06-15-2018, 10:25 PM #4
Good luck, others might have tips
1981 240D 498,000
1975 HJ45 ???,000
NZScott
1981 240D 498,000
1975 HJ45 ???,000
