Thread Rating:
  • 1
  • 2
  • 3
  • 4
  • 5
Noise dissapears above 2000rpm
addi.bigg Offline
OM605; 7,5mm elements
#1
OM605 7,5mm Dieselmeken elements, mechanical pump. Timing is in place, adjusted to the stock value.
The symptom is that while running in low rpm (1200-1300rpm), pressing the throttle pedal to speed up, some strange noise comes, some knocking which sudennly dissapears at 2000rpm. It seems like something is a bit late while increase the rpm and it's gain on at 2000rpm. Nothing above it. It always dissapears in the same rpm.
Any ideas what that can be?
02-07-2018, 12:38 PM
Find Reply
CutWeldDrive Offline
#2
RE: Noise dissapears above 2000rpm
as far as i know the 7,5mm Dieselmeken elements have a different timing value to stock.
someone maybe able to confirm or tell me i'm talking crap.
but nearly sure i saw this somewhere
02-08-2018, 11:50 AM
Find Reply
Mr.Emo Offline
Nissan Patrol -> 606 conversion.
#3
Yeah, they usually send out instructions with the pump.
02-08-2018, 12:18 PM
Find Reply
addi.bigg Offline
#4
(02-08-2018, 11:50 AM)CutWeldDrive Wrote: as far as i know the 7,5mm Dieselmeken elements have a different timing value to stock.
The quantity is low 85-90ccm. I'm really not on the borderline from the upper side.
02-09-2018, 01:03 AM
Find Reply
addi.bigg Offline
#5
If the oil pump chain is not tight enough what kind of noise it can make?
02-09-2018, 01:04 AM
Find Reply
barrote Offline
#6
Mos probably the noise u mention is nailing due to excess advance in low rpm.
Once the threshold is passed it goes. Replace timming sprocket by a 605 N/A.
02-09-2018, 04:56 AM
Find Reply
addi.bigg Offline
#7
(02-09-2018, 04:56 AM)barrote Wrote: Mos probably the noise u mention is nailing due to excess advance in low rpm.
I've sent you a pm.
02-12-2018, 03:07 PM
Find Reply
addi.bigg Offline
#8
https://www.youtube.com/watch?v=NuL12eCn...e=youtu.be
Any suggestions regarding this noise?
This is the one that dissapears. If the engine is cold it is louder.
(This post was last modified: 02-13-2018, 12:45 PM by addi.bigg.)
02-13-2018, 12:42 PM
Find Reply
addi.bigg Offline
#9
(02-13-2018, 12:42 PM)addi.bigg Wrote: https://www.youtube.com/watch?v=NuL12eCn...e=youtu.be
In this you can hear when the noise dissapears.
https://youtu.be/GK_naRLhslk
02-13-2018, 12:44 PM
Find Reply
NoFear Offline
#10
Same problem. What is the solution?
08-07-2019, 12:43 AM
Find Reply
barrote Offline
#11
Those engines in the videos sound really bad... my sugestion on the advance mechanism is still valid.
Check out it is working properlly. Sometimes they do not, cause of a design flaw. Using a older 605 N/A solve the problem.
But its definetly timing related... its god damm advanced...
08-08-2019, 09:25 AM
Find Reply
NoFear Offline
#12
08-14-2019, 01:45 PM
Find Reply
Forum Jump:
