2002 Ssangyong Musso
That is silly about the head gasket.
would I be ok with composite H-gasket with 10-15 psi boost
So the 602.982 rod has the same big end
why did you use the 601.970 piston why not the 602.982 same pin size 28mm?
Is there a stock pump that already has the 6mm elements inside
id like a turbo range from 1200-4000 for towing would stock be ok and to get the 200hp
Love the intercooler pipe work
cheers heaps
