2002 Ssangyong Musso
(09-12-2019, 04:05 AM)Buzzliteyear Hi Baldur, my first post and thanks for sharing this info
I have 100 question but ive restrained myself to 5ish
is there no MSL head gasket for the OM662
No. And the OM602.980 engine which shares the same block but was direct injection had a composite gasket, which is really silly considering how sturdy the rest of that engine is.
why did you use the OM601.970 pistons (was it wrist pin size) 28mm over 24mm for musso ?
Yes, 28mm over the standard 26mm. Needed because the 602.980 rods have the 28mm pin.
did you bend the stock OM662 rods because of your 20psi boost
No I was running 35psi boost and a 7.5mm pump. Bent 4 rods out of 5.
did you re balance the motor for the heaver rod
No.
would stock rods be fine for 10-15psi boost or do this 662 fail with age
20psi and 6mm elements is what the standard rods can handle. These rods do fail with age also, around 300000km because of fatigue.
the quote I got from dieslmeken for 7.5mm pump is more than the purchase of both my OM662engines, is there a way to
get power around 200hp (350nw) staying with full manual pump and looking at lpg injecting
6mm elements will give you 200hp. Standard rods cannot handle the torque of 7.5mm.
No.
