Thread Rating:
  • 1
  • 2
  • 3
  • 4
  • 5
W202 om605 edc project from the uk
Jamie_stafford Offline
#1
Hi everyone, I have been looking around this site for a couple of years now but I have only just picked up my project car!
It's a 1998 C250td auto, I was looking all over the country for one for quite a while but waiting paid off as the perfect car came up for sale 10minutes from my house!
[Image: IMG_20171112_194728-L.jpg]
[Image: IMG_20171120_071616-XL.jpg]
[Image: IMG_20171127_201818-XL.jpg]
This build isn't going to be anything crazy just a good fast daily, to4e turbo, manifold adapter, ecu from synat (when I sell my subaru) etc,
I have fitted a big k&n air filter along with egt and boost gauges, egr delete and done the resistor mod with a 4k3ohm resistor on a switch, goes very well and will do me until the rest comes together, I am a welder/fabricator so making things won't be an issue,
12-30-2017, 02:33 PM
Find Reply
R-3350 Offline
Dreaming of compounds
#2
RE: W202 om605 edc project from the uk
nice looks like a good daily that should be fun. which T04E are you looking at/running? i see the various trim compressors output from ~44-56lb/minute. i might look at something slightly more modern in the same flow range. there are a few newer Holsets that should be good and quite cheap. the HE351WG comes to mind. anyways good luck hope it turns out fun.
12-31-2017, 12:02 AM
Find Reply
#3
It's only an ebay to4e, when it's all on I will start to look at bigger pump elements and possibly a new turbo, this one should be good to max my original pump
01-03-2018, 04:55 AM
Find Reply
#4
[Image: Screenshot_20180101-121611-L.png]
01-03-2018, 04:56 AM
Find Reply
R-3350 Offline
#5
looks ok i wouldn't count on it lasting forever i also wouldn't push too much boost with that. that being said who knows i have seen some china turbos last forever i high boost applications. does yours have a 722.6 behind it? if so a trans tune can help make it more responsive as well. im not sure who does stock tcu tunes however i have heard good things about the improvement in drivability from the aftermarket tcu's.
01-03-2018, 12:57 PM
Find Reply
#6
I think it is a 722.6 and it would be nice to tune the box a little,
01-05-2018, 02:54 PM
Find Reply
#7
Tonight I had some tinkering time so I got rid of all the old plastic boost pipes and the egr unit, then fitted some new boost pipes, the engine bay looks a little one sided now but it has opened up a nice big space for the to4e Smile
 [Image: IMG_20180105_173843-L.jpg]
(This post was last modified: 01-05-2018, 02:58 PM by Jamie_stafford.)
01-05-2018, 02:57 PM
Find Reply
#8
Well I offered up my Chinese to4e turbo tonight, it's going to be tight but should go in ok!
[Image: IMG_20180112_184632-L.jpg]
01-12-2018, 02:10 PM
Find Reply
iDiesel Offline
#9
I imagine this car giving out more power than i coud ever dream about,looks nice!
01-12-2018, 03:03 PM
Find Reply
#10
Thanks! Wont be massive power, this setup should let me max the original pump so upto 250bhp should be seen on this setup, and keeping the auto box it should be a good daily Smile
01-13-2018, 01:32 PM
Find Reply
juggs Offline
#11
Be interesting to see how this goes & if the spool up is reasonable with the T04e.
What exact size did you go for in the end the one you posted, AR.50?
I’m running a similar set up & so is Charlie, we both using gt2871 China turbo’s & neither have had an issue so far.
Are you planning on retaining the stock intercooler & exhaust?
01-14-2018, 07:19 AM
Find Reply
#12
Yes it's the one I posted, I will be upgrading the exhaust to 2.5in and upgrade the intercooler as soon as possible, I am looking at fitting a 3bar map sensor and running 2bar,i don't mind being a test mule to see how it holds up Wink
01-14-2018, 03:57 PM
Find Reply
Mallinman Offline
#13
Have you got a flow chart for that turbo????
L200 manual om605  7.5mm
01-14-2018, 04:49 PM
Find Reply
#14
No sorry I don't, I would like one myself though, not sure how to get hold of one
01-15-2018, 02:59 PM
Find Reply
STDGer Offline
#15
Hey Jamie,
Im glad to see ur on progress.
I think the t04e would be a bad choice with 722.6 on 6mm, but lets see how it spools.
i will give u a good advice to build ur t3 triangel adaptor with a massiv pipe, something like 70mm or bigger. it will increase ur power massivly
greetings from germany, my t04e is still holding the 2 bars Wink
ex 04. 1997 w202 om605 sedan ,Dieselmeken 7.5mm, 3" exhaust, he351w, 716.657 ca 350+ hp
actual 08. 1997 w202 om605 station wagon, oem edc pump, modded exhaust manifold, t04e turbo, oem pipe 1 silencer wannabe as much as possible
01-17-2018, 02:38 AM
Find Reply
#16
Thanks, I have been looking at at how big I can get the outlet from the manifold, it's definitely going to be a good learning curve!
01-17-2018, 07:41 AM
Find Reply
juggs Offline
#17
STDGer you have this same set up on your car right, running a stage 2 mapped Ecu off of Sean right?
Is your car a manual & do you use the resistor/evry mod as well?
What sort of RPM is your car coming on to boost?
What RPM do you get full boost by?
01-17-2018, 08:31 AM
Find Reply
STDGer Offline
#18
Yes ur right.
i ve a manual and sean s map s2
Ive welded a t3 adapter direkt to oem manifold to keep the oem look of the engine bay.
at 2k it will make a light breeze of around 0.3 bar.
1 bar at 3.2k full on around 3.6 in 3 gear
01-17-2018, 01:16 PM
Find Reply
#19
Made some good progress this weekend, gotgthe to4e fitted!
Made up a manifold adapter from some 50mm id tube,
[Image: IMG_20180223_151142_299.jpg]
[Image: IMG_20180223_151142_302.jpg]
[Image: IMG_20180223_162225.jpg]
[Image: IMG_20180225_001956.jpg]
Very happy with the result, I see about 1.4bar by 3.5k, so I am very happy about that seeing as mine is an auto, still only have a 3.9 resistor on a switch, seems more than enough fuel for now,
1998 C250td, om605, 722.6, stock edc, to4e
02-28-2018, 03:02 PM
Find Reply
Forum Jump:
