Thread Rating:
  • 1
  • 2
  • 3
  • 4
  • 5
320x30mm brakes on w201
EvoPeter Offline
#1
Bought a set off front brake calipers with partnr 0014200083 and 0014200183. They are from w124 500e/r129 600SL.
I have r129 spindels but there is no threads on the calipers. CC on 500e calipers to mount on spindle is 100mm and on standard w124 brakes it is 110mm.
Im confused. ?
[Image: 20171216-160353.jpg?width=150] [Image: 20171216-160349.jpg?width=150] [Image: 20171216-160337.jpg?width=150] [Image: 20171216-215918.jpg?width=150]
12-16-2017, 05:04 PM
Find Reply
R-3350 Offline
Dreaming of compounds
#2
RE: 320x30mm brakes on w201
those look just like a set of calipers i pulled off of a 1995 s600. the spindles on that car were threaded and im not sure it used the same front suspension set up as a 129.
12-17-2017, 12:20 PM
Find Reply
hents99 Offline
#3
I don`t have experience with iron calipers but I have installed W220 front calipers (also for 320x30mm rotor) to different models like W201/W124/W463.
Fits with adapter.
ML(from 2002 models) front calipers are basically same as W220 but for bigger rotor 345x32mm. 17" is minimum wheel diameter.
http://www.elbe.ee - MB performance parts.
W201, C126, W203
12-18-2017, 03:58 AM
Website Find Reply
EvoPeter Offline
#4
(12-17-2017, 12:20 PM)R-3350 Wrote: those look just like a set of calipers i pulled off of a 1995 s600. the spindles on that car were threaded and im not sure it used the same front suspension set up as a 129.
Strange is that this part# for these calipers is the same as w124 500E.
12-19-2017, 03:10 AM
Find Reply
hents99 Offline
#5
Seems to be from W140?
I have same caliper here from W140. Bolt CC is 100mm.
[Image: Photo-19-12-2017-13-35-36.jpg]
[Image: Photo-19-12-2017-13-35-19.jpg]
W201/124 has 110mm like you mentioned before.
W201, C126, W203
(This post was last modified: 12-19-2017, 06:41 AM by hents99.)
12-19-2017, 06:40 AM
Website Find Reply
EvoPeter Offline
#6
(12-18-2017, 03:58 AM)hents99 Wrote: I don`t have experience with iron calipers but I have installed W220 front calipers (also for 320x30mm rotor) to different models like W201/W124/W463.
Fits with adapter.
Ok. Will look into making an adapter.
12-19-2017, 09:56 AM
Find Reply
EvoPeter Offline
#7
[Image: 320mm-bromsar.jpg]
12-19-2017, 10:10 AM
Find Reply
hents99 Offline
#8
Fits with adapter.
I can send you adapter drawing if you like.
[Image: 66337-DSC_0583.jpg]
W201, C126, W203
12-21-2017, 03:18 PM
Website Find Reply
EvoPeter Offline
#9
Fits with adapter.
It would be awsome.
evopeter@hotmail.se
12-22-2017, 01:34 AM
Find Reply
EvoPeter Offline
#10
(12-19-2017, 09:56 AM)EvoPeter Wrote: Ok. Will look into making an adapter.
I can only find that W220 had 312mm or 330mm discs. Was looking at scrapyard and saw that i can get a pair of brembos aluminium from W220 for around 200Euro.
12-27-2017, 10:44 AM
Find Reply
hents99 Offline
#11
Maybe some private seller could offer you better price.
We use to pay up to 100 euros for pair of W220 calipers.
Maybe was 330mm discs. Last time I installed W220 calipers to W463 rear axle....Cheapest conversion ever :Smile
You can use C32/C55 W203 front rotors as well. 345x30mm (ML has 345x32mm like mine but I made aluminum center parts). Minimum 17" wheels required.
W201, C126, W203
(This post was last modified: 12-28-2017, 07:28 AM by hents99.)
12-28-2017, 07:27 AM
Website Find Reply
EvoPeter Offline
#12
(12-28-2017, 07:27 AM)hents99 Wrote: Maybe some private seller could offer you better price.
Well, found a pair of C32/C55 w203 AMG calipers for 345mm rotors for 100Euro on the scrapyard so i send back the other iron calipers for the 320mm rotors.
Now i have a set of 320x30mm rotors i dont need.  Rolleyes
12-29-2017, 07:58 AM
Find Reply
hents99 Offline
#13
Good. W203 calipers are basically bolt on with c32/55 rotors.
Just need to use some shims for correct offset.
W201, C126, W203
12-31-2017, 04:23 AM
Website Find Reply
Mr_Robs Offline
#14
Are there any calipers worth upgrading to on the 124 that will still fit under 16in wheels?
I have some used 400e calipers but if theres something larger but does not require 17 inch wheels id rather upgrade before rebuilding these 400e ones.
01-05-2018, 05:21 AM
Find Reply
maxypriest Offline
#15
W124 - I'm using R129 iron 4 pots with W210 16" alloys (A210 401 06 02) and they JUST fit (1MM of clearance).
They don't poke out much from under the arches either at j7.5".
I have a set of iron W140 4 pots and they are MASSIVE and just don't fit my car/any of my wheels.
01-09-2018, 11:26 AM
Find Reply
Forum Jump:
