STD Tuning Drivetrain ML270CDI 722.661 into W124
BobbyBreeze
08-29-2017, 04:51 PM #1
Anyone know if the ML trans can be used in RWD application (w124) easily? I have seen pictures of the transfer case removed but I am not sure if the driveshaft yoke can be easily attached to the output shaft?
[Image: 1448960819730_bulletin]
The ML270CDI 722.661 is the easiest strong box I can find locally, there are no C270 CDI's around and all the v8 transmissions are much more expensive.
Thanks
BobbyBreeze
Thanks
ross
08-31-2017, 05:32 AM #2
The rear output 'cup' is held on with the same arrangement the flex disk mount uses as far as I could tell on mine.
ross
BobbyBreeze
08-31-2017, 05:24 PM #3
Thanks Ross, that is sounding promising!
BobbyBreeze
ross
09-01-2017, 07:24 AM #4
I will add its a while since I looked at it!
ross
