German 605 s202 t04e undercover Projekt
The rad is cold but the engine is hot?? is the bleed pipe from the rad to the header tank clear? there is big air pocket in the top of the head if that is not clear or even installed..
Maybe water pump impeller is broke if it is the plastic one? I still didn't over heat when mine was broken in two!
Visco coupling bad? Can you spin the fan easily by hand when it is hot?
Should sit at 78 degrees all the time and go upto 80/85 after a hard drive then idling for abit..
