STD Tuning Engine will i need to build new exhaust?
Devil3344
05-25-2017, 02:13 AM #1
I have a s124 300tdt (om603), engine is original with adjusted diesel pump and turbo pressure. Is there more horse power to pick up if I build new exhaust in 3 "or are there other things I can do?
Devil3344
Devil3344
05-27-2017, 06:05 PM #2
No one?
Devil3344
No one?
awsrock
300SDL / HX30 / 90cc
179
05-27-2017, 07:34 PM #3
Aadjusted to max or with bigger elements? Either way, stock exhaust is kind of small, some bends get down to 2". You will gain some n/a torque as well as flow a bit better in high rpm but the more fuel you have the more you will notice it
awsrock
mrfajita
05-29-2017, 11:04 PM #4
Mine is 3" straight pipe from the second turbo all the way to the bumper. Works fine with my compounds, but I'll see if it needs upgraded when I upgrade my injection pump. Unfortunately due to the layout of my engine bay I can't fit larger than a 3" downpipe, and even that had to be oval pipe and requires a hammer to install
'77 300D, 617.912, HY35 15psi, 3" side pipe, maxed out stock MW pump (Sold, now converted into a ute)
'87 300TD, 603.960, questionable mods from the PO including a ghetto 3" straight pipe
mrfajita
Devil3344
05-30-2017, 08:44 AM #5
(05-27-2017, 07:34 PM)awsrock Aadjusted to max or with bigger elements? Either way, stock exhaust is kind of small, some bends get down to 2". You will gain some n/a torque as well as flow a bit better in high rpm but the more fuel you have the more you will notice it
Pump is orginal, no bigger elements..but i can probably adjust a little more on the pump, but not mutch.. i removed the catalyst and the last silencer, but i still feel the exhaust does not go out fast enough..
Devil3344
