STD Tuning Drivetrain 270cdi pressure plate..
bruno_pinho
01-10-2017, 02:22 PM #1
Anyone can tell if the 270 cdi pressure plate is directly plugged into the om605 dual mass flywheel?
bruno_pinho
Flo.Pe
01-22-2017, 03:58 AM #2
Yes it will fit the OM605 DMF, only when you use the 5 speed gearbox from W202 C250TD then you must reduce the max way from the clutch pedal (2mm at the pedal stop point) because the throw out fork grind on the pressure plate housing.
Flo.Pe
dieseltorque
04-11-2017, 03:27 AM #3
Hi, if the pressure plate fits, then clutch disc from 270 cdi fits there aswell or not?
dieseltorque
