Modify an m104 tachometer to work with an om603?
Grüße
Thank you very much, this is exactly the information I was looking for. Did you try multiple capacitor values before arriving at this solution? Do you think matching the capacitor value of the original 6k diesel tach would be a good starting point?
I think I found a burned resistor on the diesel tach so I'm going to try replacing that one, then give the gas tach another try if that fails.
Cheers
