FAQ EDC Pumps / W202/W210 W463 ECU’s
(12-22-2016, 03:54 PM)seanyt From dieselmekens edc video i always thought idle was 1.95v with 11.3cc injection.
when im at my home pc i will check the voltage map to see what voltage is used a cc injection.
Ive not had anyone yet exceed the 4.5v limit on the maps ive made so far for people.
Are you thinking of setting idle quantity of 10cc at the 1.25v position?
two issues i think would be, 1.25v is too low for the idle control loop if it wants 1.95 and it would hunt or not idle at all.
another is you only have 1mm of rack travel to completely shut off all fuel through the elements is this enough?
Unless im thinking about this wrong.
I thought the limit for the rack travel sensor was 5v as this is the usual reference for sensors not 6v.
giving a 10% margin for the 4.5v limit.
Ive seen one case on the forum where the pump solenoid was machined to extend rack travel.
this being used by baldurs standalone ecu, this is the only ecu that will give you full access beyond the 4.5v sensor limit for very big HP builds.
You can trick the rack sensor by placing either resistors on the rack reference to get more travel or on the signal to get less travel,
there is also an adjustment at the back of the pump that moves the sensor,dieselmeken used this to gain 1mm travel having idle injection quantity at 5.7mm rather than 6.7 at 1.95v giving 1mm of added travel to the rack.
what do you mean by this
another question is the rack feedback... how needed is the 2000mV for a tune of course....
