FAQ EDC Pumps / W202/W210 W463 ECU’s
hy seanyt ,
wonderfull job u´ve done congratulations,
as of me i keep the hardware side of things and a few questions to consider.... like :
The electroactuator has 17mm range, phisicall range so with some magic 16mm can be used ! my question is , having idle at 1mm actuator (8 to 10cc) need more or less 1.25volt , can the software handle this small amount of voltage and use 0 voltage as measure to recover idle (low recover)? and how sensitive can u make it to 1.50 volt for steering , ac , t/off recover ( high idle recover)?
about max actuator position (the 17mm), is the ECU able to pass over 4.5 volt to achieve that ? (tipically in a 7.5mm pump about 6volt is needed to achieve full extention? another question is the rack feedback... how needed is the 2000mV for a tune of course....
Thanks , usually i build the pumps not the maps... so many questions/answers i have for the mappers .
i belive is possible to mod the actuator to reach around 20mm extention, but still, a the max voltage problema apply? (or not)
regards
